[help needed] Proteus f7 in s52"tu" turbo swapped 318ti
ThornyPotato
Post by ThornyPotato »
hello all, I am running a s52 with a modified head to hold dual vanos cams, and a gt35 turbo. I have a custom wiring harness, aftermarket intake with a dbw throttle body (m62b44) and e46 pedal. motor is lightly built, eagle control arms, king bearings, arp main and head studs. stock everything else, looking to make 500-600 reliably. having issues getting the trigger set up right, I have a good crank signal but it keeps loosing sync and cam seems to come and go, not sure why. I've double checked wiring and it all seems sound, do the vvt outputs need to be assigned with proper pid/angle settings for it to sync? I was running a speeduino ms42 pnp and i've borrowed a few things from the base map to hopefully make it easier to get started.
Re: Proteus f7 in s52"tu" turbo swapped 318ti
