So I've decided to purchase a bright orange vehicle, again with Honda K engine, this time GDI and turbo-charged! And Acura Care Extended Warranty
2021 Acura RDX
2021 Acura RDX
Many years ago I had a not so bright orange vehicle with a Honda K engine. It has blown the head gasket for not good reason
Re: 2021 Acura RDX
Hold on, does this vehicle have THREE separate CAN buses?!
https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/Honda/2021-Acura-RDX-data-lines.pdf
Power steering uses one bus but electronic gear shifter uses two? Two buses between ECU and ECU?
Re: 2021 Acura RDX
Active Dumper System, the less fancy one without stroke sensors like on Civic Type R.
Why do they run two dedicated wires to each strut solenoid? Why not shared high side?
Re: 2021 Acura RDX
Splices are less reliable than running a separate wire to the ECU. Splices are probably actually more expensive too, since they need an extra step of joining multiple wires together, rather than just "wire with something crimped either end" which you can automate.
Re: 2021 Acura RDX
I think it uses an NTK wideband so we have a chance to poke into a running vehicle
Internet says
Blue = Heater +
Yellow = Heater -
Grey Wire = Vs
White Wire = Ion Pump
Black Wire = 0v
My multimeter says 3.5Ohm between blue and yellow, and I have a patch cord ready for poking
Internet says
Blue = Heater +
Yellow = Heater -
Grey Wire = Vs
Black Wire = 0v
