At the moment there are hopes around https://github.com/rusefi/rusefi/wiki/Ion-Sense which would mean using one of a recommended COPs. We are months away from a working prototype and many months away from the complete solution.
Proteus v12 club
Re: Proteus v12 club
Most 4 pin coils are actually power, ground (power), ground (signal) and signal. That's the pinout on LS coils.
bill
the Ion Sense will be some kind of "dumb " coil, ( Simon is using the Mini coil currently) and a custom board from rusefi--
Until that happens, i am using GM "Yukon" coils on my V12-- seem to work well, fitting into the tight spark plug hole... and cheap at the junkyard...
codyao
Got kinda bored with my luxury coupe idea and thought about scrapping it, but then I saw this and got some wild inspiration and motivation. Going to drop my M73 in a Z3. Judt got the engine to the machine shop to extract the broken headbolts and I have all the bits to rebuilt it ready to go. Now to find a cheap broken Z3 and figure out a good manual trans fit
bill
Well, you are at the right place... My plan for the M73 is to drop it into a Z4 E85!
The easiest fit manual tranny is a from a 540i
We all look forward to your Z3 build!
soon there will be a VEE12 Z3 and a VEE12 Z4 roaming the streets
mk e
Z3? Z4?
This is going to be GREEEAAAT!
JRockland
Do you have a model number by chance ? Im far from any scrapyard so my options are limited to internet search..bill wrote: ↑Sat Jan 09, 2021 2:27 pmthe Ion Sense will be some kind of "dumb " coil, ( Simon is using the Mini coil currently) and a custom board from rusefi--
Thank !
bill
i guess you call them LS coils
i grabbed from the junkyard, but you can get them new on eBay for not much money
the "yukon" ones have little metal bits on top
https://github.com/rusefi/rusefi/wiki/Vault-Of-Ignition-Parts
mk e
That's what I use...the yukon D585 ones which are supposed to spark the hottest. They were like $10 each and came in ferrari red
mk e
bill
yea , the junkyard charges $8 used
so 10 pesos is a deal
" COIL ELECTRONIC $8.57 $0.00 $0.00 $0.00"
bill
JRockland
I would love too but I have no clue how to post pic..
mk e
Easy!
1) click on the attachment tab
2) click Add file
JRockland
nice ! Ill give a try as soon as I have interesting photos to share. Ill post in the "my project" page
JRockland
They look great, but they still use a cable right ? I might try to find something like what is on the m62b44.. If it fit with the headers. if not this is gona be my option. And I love the idea of red !
Yes, all LS coils (GM pushrod V8 engines after 1997 or so) have individual coil-near-plug with a short wire to the plug.
Factory setup puts the coil up on top of the valvecover, since the plug is down on the side (2 valve pushrod cylinder head):
mk e
For me I just wanted the plug wires to kind of keep it looking 1980s with plug wires running across the cam covers as original so these were perfect. For sure that not a concern for most builds but I personally think it looks right/good on older stuff.
JRockland
Soo yea took a look at the engine and realized the sparkplug goes right between headers.
Cable it is.
Is double spark plug a thing in cars ? I'm use to built motorcycle engine and in Harley's we would drill a second hole to get 2 spark per cylinders. never seen that in cars. just a question.
Cable it is.
mk e
It is a think sort of. Its common on air cooled 911 engines and top fuel cars run 5 plugs I think, all airplanes have 2. On planes it a reliability thing, 2 separate ignition system. On early porsche and Harley the chamber design blocks the plug on high CR setups requiring stupid high timing advance so adding a 2nd plug increases hp by allowing more reasonable advance. Fuel motors the stuff burns so slow any little bit faster helps make hp....so 5JRockland wrote: ↑Sun Mar 21, 2021 5:36 pmSoo yea took a look at the engine and realized the sparkplug goes right between headers.
Cable it is.
On a center plug 4 valve and most modern 2v design that is not the case and there is no power to be gained so no reason to go to the bother.
