[rusEfi] Two stroke Efi (#14)
Re: Two stroke Efi
I´m waiting for parts, maybe +15 days.
Re: Two stroke Efi
what it is?Number-One wrote:Arrived
Re: Two stroke Efi
Smd resistores and capacitores.
Re: Two stroke Efi
oh , right . just never saw packing for SMD.
Re: Two stroke Efi
Jared, do we have the q401 resistor channel side flip documented somewhere? In case Filipe would be using q401 for ignition control?
Re: Two stroke Efi
I don't' think I fully understand the question, perhaps that's because I'm assuming my cryptic schematic is clear What I was trying to indicate, is that normally R402 is 0 ohms, and R401 is not populated. Then if you need that funky ignition circuit which was found on at least one engine setup, you would populate R402 with a 100 ohm 1 watt thru hole resistor, and R401 with a 75 ohm 1/2 watt thru hole resistor. If you have any more questions feel free to ask.
Re: Two stroke Efi
The reason to consider this trick here is that it's easier to buy fewer kinds of different parts - since only one coil is needed this would eliminate the need in TC4427
Re: Two stroke Efi
One more step, still waiting for parts.
one week more to be finished
Re: Two stroke Efi
First video
Re: Two stroke Efi
You could probably engage the starter under normal use, and call that a hybrid It's cranking right along in that video. I'd bet it slows down once you have compression.
Does this mean you can attempt a capture of the crank signal pattern? I'm not sure how far along you have gotten the soldering.
Re: Two stroke Efi
This's to check the starter motor only. The engine it's without cilinder head, need adjust head compression to this piston.
Re: Two stroke Efi
Re: Two stroke Efi
Engine closed and working with carburator. Next step, fit itb.
Re: Two stroke Efi
it's great sounds .
Re: Two stroke Efi
I've added some info regarding triggerinfo command on the wiki: http://rusefi.com/wiki/index.php?title=Manual:Software:Trigger#Troubleshooting_trigger_input
Re: Two stroke Efi
Also a new wiki page: http://rusefi.com/wiki/index.php?title=Manual:Software_Temperature_Sensors
Re: Two stroke Efi
I've changed the input pin for you so that you do not need to re-solder anything. Please update to latest version of the firmware and execute 'set_engine_type 29' to re-apply your configuration.
Once you do that, your triggerinfo command would start showing PA5 as your input pin:
I believe you should be able to change the input pin via TunerStudio also.
Re: Two stroke Efi
Thanks, tomorow morning i will test it.
Re: Two stroke Efi
VR input works!
Now I need to count how many small teeth I have after the wide tooth.
Re: Two stroke Efi
Looks like we are getting closer
What is your plan for sensors? What are all sensors you have and what are you going to use for engine load - TPS/MAF/MAP?
Re: Two stroke Efi
Injector is pulsing
Re: Two stroke Efi
russian wrote:Looks like we are getting closer
We can trie map or tps.
Re: Two stroke Efi
if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Re: Two stroke Efi
Maybe i will do it by tps, because my engine only have one cylinder and the map signal isn't constante, it´s like a wave. I think will be hard tune it with map sensor.puff wrote:if you do a tps setup, could you please record a screencast? or just a brief tutorial?
Re: Two stroke Efi
Wait a second, this is taken care of! You do not need to worry about the wave.Number-One wrote:because my engine only have one cylinder and the map signal isn't constante, it´s like a wave.
It is also a wave for a 4 cylinder, that's why we have MAP sampling start angle and MAP sampling window angle, and then we average the values within that window. I guess the same would apply to your one-cylinder same exact way as we average a piece of 1st cylinder wave.
Re: Two stroke Efi
russian wrote:Wait a second, this is taken care of! You do not need to worry about the wave.Number-One wrote:because my engine only have one cylinder and the map signal isn't constante, it´s like a wave.
Re: Two stroke Efi
Working.
Working.
Re: Two stroke Efi (#14)
Hooray, first rusEfi two-stroke
Congratulations and welcome to the club!!!
