rusefi.com • Hello from central NJ
Posted: Fri Jan 13, 2017 2:40 am
by Javidrifter
Hello from Central New Jersey in USA My Name is Javier I have a 1985 Toyota corolla GTS with a black top 20 valve 4AGE.
Re: Hello from central NJ
Posted: Fri Jan 13, 2017 3:02 am
by Abricos
Hi ...
Welcome ...
Posted: Fri Jan 13, 2017 3:06 am
Oh RWD Corolla :)
Posted: Fri Jan 13, 2017 4:16 am
by stefanst
Where in central NJ are you?
What are your plans?
Welcome to the fun discovery that is rusefi :)
Posted: Fri Jan 13, 2017 10:36 am
Welcome and good to hear from you.
Have you found the wiki? Just in case you have not here's a link you might be interested in. http://rusefi.com/wiki/index.php?title=Manual:Hardware_Frankenso_board
Posted: Fri Jan 13, 2017 3:09 pm
by Javidrifter
stefanst wrote:Where in central NJ are you?
I'm in Middlesex county
I am interested in the FRankenso, I would like to get the un assembled kit & put one together
I have read through the wiki's several times & decided to start posting my project to get some feed back from the community. I am an ASE master tech with 14 years of experience, also I have been racing cars for 18 years.Hopefully I can be helpful to the community ,I feel building an ECU would be a great learning experience & I'm very excited to get started. :mrgreen:
Posted: Fri Jan 13, 2017 3:12 pm
You need soldering paste & https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
If your position sensors are Hall-effect you can maybe get away without soldering paste. There is that http://rusefi.com/forum/viewtopic.php?f=4&t=425 topic relevant to that.
Posted: Fri Jan 13, 2017 4:08 pm
by Javidrifter
russian wrote:You need soldering paste & https://www.tindie.com/products/russian/frankenso-04-diy-kit-/
My crank trigger / cam position sensor is a hall effect inside of my distributor.
Posted: Fri Jan 13, 2017 4:15 pm
Javidrifter wrote:My crank trigger / cam position sensor is a hall effect inside of my distributor.
That does remove the requirement of soldering the smallest pitch MAX9926 chip. With Hall Effect sensors I see Frankenso assembled (without secondary USB/TTL chip which you can live without) with only soldering iron and soldering wire.
Posted: Fri Jan 13, 2017 6:03 pm
ASE master tech, that's cool. I'd bet you can teach us some cool tricks :)
If you have any questions feel free to ask. If you assemble your board, I suggest starting with the 5V regulator first, as well start with the regulator itself first. It's a large chip on the ground plane. That can be a bugger to get hot enough.
Posted: Sat Jan 14, 2017 3:24 am
by Javidrifter
kb1gtt wrote:ASE master tech, that's cool. I'd bet you can teach us some cool tricks :)
Great thanks again I will let you guys know when I get the kit
Posted: Wed Jul 01, 2020 11:36 am
by Javidrifter
Hey guys its been a while, I just ordered my Frankenso DIY kit.
Posted: Mon Oct 05, 2020 8:35 pm
Oh your are only a few miles away from three of us here in NJ :)
Are you still playing with the 1985 Toyota corolla GTS or do you have a Miata already? :)
Posted: Fri Oct 29, 2021 12:39 am
by Javidrifter
Still messing with the AE86 now I'm fitting a K24 engine from a TSX
Posted: Fri Oct 29, 2021 1:25 am
https://rusefi.com/forum/viewtopic.php?p=42855#p42855
