With the eBay guy I would ask him for "three for the price of two" kind of deal
Re: Looking for a solution for the Subaru EG33
Posted: Sat Jan 28, 2017 1:16 am
by sleepingAwake
russian wrote:With the eBay guy I would ask him for "three for the price of two" kind of deal
Why do you say that?
Posted: Sat Jan 28, 2017 1:19 am
Same guy used to have my favorite 64 pin connector - I believe he is a new old stock dealer. The price have started at $10 for qty 3 shipped but slowly tripped over the years until his stock has depleted.
Posted: Sat Jan 28, 2017 1:21 am
by sleepingAwake
russian wrote:Same guy used to have my favorite 64 pin connector - I believe he is a new old stock dealer. The price have started at $10 for qty 3 shipped but slowly tripped over the years until his stock has depleted.
Ah. That's good info. Thanks.
Posted: Tue Jan 31, 2017 10:55 pm
by sleepingAwake
Ive ordered a few parts that were either missing from the diy kit or optional.
4.7uf 50v cap CGA4J3X5R1H475K125AB qty 10
Blue led LTST-C170TBKT qty 5
Red led LTST-C171KRKT qty 10
Green led LTST-C171GKT qty 10
Connector 178780-1 qty 1
10uf 25v cap TMK316BJ106KL-T qty 10
4.99k resistor RK73H2ATTD4991F qty 10
1k resistors CRCW08051K00JNEA qyt 10
Posted: Tue Feb 07, 2017 4:04 am
by sleepingAwake
Current status update.
Still need to order some more parts. But it lights up and I haven't lost any magic smoke.
Posted: Tue Feb 07, 2017 4:28 am
Sweet sweet progress. Keep it up.
Posted: Thu Feb 09, 2017 11:00 pm
by sleepingAwake
More stuff and things happened today.
At some point maybe I could help with editing the instructions on software setup located in the wiki.
Currently they are a little confusing and some of the screenshots could use an update.
But they were good enough for me
Posted: Tue Feb 14, 2017 11:10 pm
by sleepingAwake
I'm bored at work and currently playing around with TunerStudio and the discovery board.
Why do I get the error "Burn page 0 failed"? whenever I make a change and hit "Burn" in Tunerstudio.
I'm not dead.
Hurt my knee last year and its slowed everything down.
I've converted the SVX to a manual transmission since I last posted here.
No more TCU to talk too.
Going through the process of updating and re-configuring the Frankenso ECU as it needed an update from its last firmware image( circa 2018).
A question.
The SVX has a separate igniter before the coils. Is there anything special I should do to prevent blowing the igniter and or coils up?
Posted: Tue Jun 30, 2020 9:51 pm
What kind of special are you thinking? So far I am not aware of anything special in similar circumstances.
Special in that SVX igniters are as easy to purchase as Rooster Teeth and I'm being overly cautious.
I think the igniter is just a block of transistors but I dont know if its inverted, open collector or something to that effect.
Its early still and I have not thought about this stuff in awhile.
I'm remembering reading something about people blowing the igniters with incorrect dwell settings.
I'll have to use the google machine and the OEM electrical manual.
Posted: Wed Jul 01, 2020 5:25 pm
by sleepingAwake
Yup block of transistors.
Posted: Wed Jul 01, 2020 5:27 pm
by mck1117
Yup, default output settings should then work okay. And if you do blow up the unobtanium SVX ignitor, you can always splice in the ultra common Bosch ignitors.
I had not but just looked through your thread.
Pretty neat stuff. The talk of Mode B vs mode A2 is especially interesting and I wonder if that pertains to my board.
It may take me some time to get my older Frankenso kit going. That being said testing for a crank and cam pickup pattern is on my to do list for this week.
On EG33 version of my board I left MAX9924 for Crank #1 only. For Crank #2 and Cam VR I use NCV1124 (as they have common minus wire).
For Crank #1 I do not expect to see any issue with MAX. In case of watchdog issue I can still switch it to B mode.
Screenshot from 2020-07-02 23-44-10.png (124.87 KiB) Viewed 15958 times
Now I still havent actually wired the harness for MAF, TPS, IAC, INJ, IGN, but I have wired in the Crank and Cam sensors.
I would think I would have seen some kind of trigger pattern in RUSEFI console and it said it was connected, flashed the MIL when tested (I wired that up) but no pattern on the Engine sniffer no sensor data from the default trigger pins. However looking at the board during cranking I could clearly see the crank and cam red leds flash on the board. Clearly the board is picking up a signal. So I'll do a little digging.
I only wired up one of the Crank sensors (what I consider the primary) and the cam sensor off the drivers side bank.
Posted: Thu Jul 02, 2020 10:30 pm
by sleepingAwake
Here's a little video of the engine cranking over and the LED pattern. Reminder still no trigger input seen in RUSEFI console.
Shouldnt the Orange LED on the ST board flash with crank signal as well? I seem to remember reading that.
Posted: Thu Jul 02, 2020 11:02 pm
It looks like hardware senses the signals which is great news and the most challenging part!
Now you need to get into software. You need to be looking either at Engine Sniffer in rusEFI console or Composite Logger in TunerStudio. And please publish your tune at rusEFI online.
Since the harness is incomplete, pin assignment is also not complete for things I havent wired. That being said I have wired the crank and cam signals.
Not sure you'd want me uploading a tune until its complete unless you just want to see what I have setup so far.
I'm using RUSEFI console to check for trigger pattern in the Engine Sniffer tab and do things like test the Fuel Pump relay in the Bench Test tab... which works.
Just to be clear the Engine Sniffer within RUSEFI isnt showing trigger events. NO heartbeat there. Board disagrees.
I could post a screenshot of the Engine Sniffer but it would just be a blank graph. It does flash the different and correct pin assignments for cam/crank.
Posted: Thu Jul 02, 2020 11:34 pm
Your hardware seems to work. All the remaining answers are in your settings in my opinion. A video of the board running would not help troubleshoot your settings.
If you are looking for any help from here please upload your incomplete tune to rusEFI online.
