New car coming soon
New car coming soon
Hello from Italy!
just received the diy kit today and started soldering, i've a couple of questions:
1) apart from using the silk print on the board how can i see where each part goes? I normally use eagle cad, but it seems that the project is in kicad?
2) the usb port should be soldered on the ttl right?
3) how are written the values on the capacitors?
a part from the i've soldered quite all the big parts in a couple of hours
i'm planning on use it in my 1993 celiac turbo (3sgte) will need a lot of help!
thanks
Luca
thanks
Luca
- IMG_4720.jpg (969.31 KiB) Viewed 9074 times
Re: New car coming soon
there are position gerbers or you can use https://github.com/rusefi/rusefi/blob/master/hardware/frankenso/frankenso_PCB.pdf or you can install KiCAD
TTL could wait since you have micro USB on discovery which works just fine. Does yout power supply produce 5v volts already?
Will have to reverse all the leds but yes, it works
how do i use the pdf? seems all the layer one over the other
I made some pictures with only the silkscreen layers in my thread:
https://rusefi.com/forum/viewtopic.php?f=3&t=1353
Hopefully it can help you out too.
thanks that's really useful!junk3r wrote: ↑Wed Jun 27, 2018 10:13 pmI made some pictures with only the silkscreen layers in my thread:
i've connected w23 and the whole board seems to work, no smoke, also the discovery lighted up!
tomorrow i will start soldering resistors and capacitors, so far so good!
I would like to suggest doing sections. AKA solder in something like the CAN chips, and make sure it works, then install the MAX chip for crank decoding, etc. Doing it bit by bit can be really helpful when something goes wrong. Also if you can get you patience to allow it, doing it in small steps is handy for diagnostics purposes. Small bits really helps isolate where problems are.
To add to this, you only need to do those sections that you are going to need. A basic setup will need the power supply, trigger, analog, low side, and potentially high/low.kb1gtt wrote: ↑Thu Jun 28, 2018 2:07 amI would like to suggest doing sections. AKA solder in something like the CAN chips, and make sure it works, then install the MAX chip for crank decoding, etc. Doing it bit by bit can be really helpful when something goes wrong. Also if you can get you patience to allow it, doing it in small steps is handy for diagnostics purposes. Small bits really helps isolate where problems are.
On a related note, should an "assembly" section be added to the wiki? Not necessarily a complete guide to assemble the board, but rather a collection of links and best practices to help give the greatest chance of success, such as links to the pdf gerbers, recommendations to view the schematic in kicad, and the modular approach to construction.
moving ahead there are a lot of minor things that would be useful to have in an assembly wiki, things that was hard to guess are:ZHoob2004 wrote: ↑Thu Jun 28, 2018 8:35 pmOn a related note, should an "assembly" section be added to the wiki? Not necessarily a complete guide to assemble the board, but rather a collection of links and best practices to help give the greatest chance of success, such as links to the pdf gerbers, recommendations to view the schematic in kicad, and the modular approach to construction.
1) R1003, on the back of the board is the only component of the power supply that is not on the front and without it the power supply will shutdown after some minutes of work
2) jumper w23 to enable power to the board
3) jp01 to power lcd! i was looking for it a lot!
4) the pins for the lcd are less than the holes, only upper and lower have to be populated
5) an hint on how the leds have the polarity would be great too
i've loaded the project online on eased to search for the part number on pcb easily:
https://easyeda.com/editor#id=26d1112f5275490cba151fd4ab7e6350
then it will be nice to have a photo of the populated parts of the board and a walkthrough to test all the parts.
I would like to populate and test the whole board as i don't know what i will use in the future and i would like not to solder parts in a second time.
Also does the joystick would work ootb? It does nothing
I'm now in populate the injector part and test it, any hint?
below my progress so far i've also created two svg with the components place that can be useful
- Component place svg.zip
- (290.41 KiB) Downloaded 281 times
Would be really handy. I have not assembled one, so it would be hard for me to do, as well I'm short on time. I would suggest getting access to the Wiki and create a page.should an "assembly" section be added to the wiki?
I have confirmed the joystick working in the past (0.4 board and older firmware) but I believe I installed mine in the wrong orientation (I don't recall how exactly). In my case, I ended up melting the joystick while trying to reposition it so it works, but 3 of the 4 directions are nonfunctional in my case.
Perhaps use a multi-meter to verify that the STM's pin is changing voltage. Does that show that you are getting a signal to the STM32?
joystick allows you to navigate over the limited LCD screen
joystickinfo command in console shows how many clicks were recorded on which side.
