I Have been looking at this project for a few weeks now after stumbling across it while looking for higher performing open ECUs and I think I'm ready to jump in with both feet.
I have been going through the wiki, hardware and software forum and have just started digging through the source code.
I have just ordered a 407 Discovery board as it seemed to be the default option.
I was planning to order a kit form Frankenso board this month for the simple reason that putting it together from just the bare board should give me a much better understanding of the hardware than I could get just by reading the available info.
I get the soldering issues, I picked up a few SMD practice boards to be sure I could do it and was ok down to 0402 components, I have a 2in1 hot air SMD station with temp contorlled iron and the paste/flux for SMD stuff so no worries on that side.
For me the big draw is the potential processor performance and the open source meaing that we might finally get an affordable ECU that can run some of the newer higher technology engines.
Just seems to me a lot of the aftermarket stuff is significantly over complex or so limited as to be useless for anything more sofisticated than a Ford Zetec.
Right now we have a whole generation of great engines but due to the direct injection, VVT/VVL, variable inlet manifolds etc can only really be run properly by the OEM ECU or £10k+ standalones.
I'm certainly not new to all of this having had an MS&S unit (with hindsight - what a piece of junk), recently spent a lot of time in pre-2000 Motronic units and the day job has me working with pre-production OEM units.
I have done a little programming, most recently putting together an arduino motronic data logger for OBD1 ECUs so reasonably comfortable with the way C/C++ work.
Aplication wise I'm spending most of my time in BMW land with the first target being my E30.
I'm sure I will have plenty of questions coming up but I will keep them to the relevant forums.
A bit of a ramble, see you in the Forums.
