[README] Beginner Video Guides
Old Grey
Post by Old Grey »
I better clump these here so people can find the guides easier.
RusEFI ECU #1 : Getting Started - Firmware
RusEFI - SIMulator
RusEFI - STIMulator
Old Grey
Re: Beginner Video Guides
Post by Old Grey »
FRANKENSTEIN - Hand soldering Frankenstein.
RusEFI Frankenstein 1 - Soldering Basics
RusEFI Frankenstein 2 - Soldering Frankenstein
RusEFI Frankenstein 3 - Soldering Frankenstein
RusEFI Frankenstein 4 - Soldering Frankenstein
RusEFI Frankenstein 5 - Critical Inspection
FRANKENSO - Stencil and oven soldering Frankenso.
I made numerous mistakes when doing these videos, so watch the next video for the corrections before you do any of these instructions.
rusEFI Frankenso 1 - Soldering - Bottom Prep
rusEFI Frankenso 2 - Soldering Bottom
rusEFI Frankenso 3a - Soldering - Front Prep 1
rusEFI Frankenso 3b - Soldering - Front Prep 2
rusEFI Frankenso 4 - Soldering Front
rusEFI Frankenso 5 - Soldering THT
rusEFI Frankenso 6 - Critical Inspection
Old Grey
Post by Old Grey »
This is kind-of a tutorial on how to do a Frankenstein from plans, but done in the style of a "reaction" video. Basically lots of BS intermingled in the info.
Imbecile Vs RusEFI 1 - The Wreckoning
Imbecile Vs RusEFI 2 - Wreckoning Harder
Imbecile Vs RusEFI 3 - To Wreckon, or Not to Wreckon
Imbecile Vs RusEFI 4 - The Wreckoning is Over
Imbecile Vs RusEFI 5 - Wreckoning there is No, only Do or Do Not.
Imbecile Vs RusEFI 6 - I Wreckon So
Imbecile Vs RusEFI 7 - Frankenso Unboxing
Imbecile Vs RusEFI 8 - Frankenso SMD planing
Imbecile Vs RusEFI 9 - I wreakon it will work
Imbecile Vs RusEFI 10 - Frankenso soldering redux
Imbecile Vs RusEFI 11 - Frankenso soldering redux2
This post is now sticky, it would always be on top hopefully it's OK.
WOW, very valuable material :) Thank you for your contribution!
Yes very cool and thanks for putting in the effort on the video's. One suggestion that might make them even better is to add notes. As an example, for this video https://www.youtube.com/watch?v=izhxVPfNxu4&feature=youtu.be notes like this would be cool.
0:0 Introduction to simulator --> download --> open simulator --> simulator basics
1:48 inspect VE table data --> tips about RPM limited by threshold
2:38 sensory inputs (coolant temperature) --> gauge manipulations --> tips about warnings
4:04 Diagnostics via "messages" tab
5:13 Connecting Sim to TS --> Firmware archive https://sourceforge.net/p/rusefi/code/HEAD/tree/firmware_archive/
5:57 Virtual serial port install --> open files from the rusEFI bundle
6:24 firewall / antivirus notes --> Open virtual serial port
7:22 Start TunerStudio (TS) --> Change coolant temperature and RPM in Sim and see it in TS
8:58 Change engine parameters in TS see them change in Sim.
9:27 Connection problem diagnostics Telnet and similar tips. "telnet localhost 29001" then "telnet localhost 29002"
Perhaps this sticky thread could include the videos, while comments like this post could be in another thread. AKA perhaps this can be a handy place for educational purposes. Or perhaps the above list should be included in the wiki.... Any how I feel my comments are handy for developers and less handy for the desired end user.
cyrille
Post by cyrille »
thank you very much for these videos
media embedding seems to be fixed now?
Old Grey
Post by Old Grey »
kb1gtt wrote:
Mon May 13, 2019 9:57 am
You're good at notes, any chance you can do some ;) You're better than I would ever be.
You can put them as a comment on the vid and I can pin them, and that way everyone sees it first. I put your notes on the SIM video and it looks pretty good.
I would love to try the notes / comments. The problem is that I have normal life constraints, which mean I have a lack of time. Lately it's been hard to read the forums and slack :( I'll keep it in mind that you would like then. I'm a skeptic that I'll find the time :(
