AC Cobra / 1UZFE-VVTi
pierreroc
Post by pierreroc »
Hello, i am restoring an AC cobra replica and plan to put an 1UZFE/3UZFE-VVTi engine. I am looking for an open source ecu and rusefi seems to be a good choice. But i am wondering about VVTi control : is rusefi able to control it ? (i've seen that miata vvti works fine but here there is two inlet camshafts to control with PID). Thanks for your advices, have a good day !
Pierre (from France).
Re: AC Cobra / 1UZFE-VVTi
Hello and welcome!
This was not done yet and could not be done with the firmware as is, but I would love to have your https://en.wikipedia.org/wiki/Toyota_UZ_engine running rusEfi and very little code is needed to support to VVT intake camshafts, especially since I bet you would be running same map on both :)
So, once you have it running without VVT let me know and I will get you the missing additional logic.
Is this electronic throttle or mechanical throttle? Do you have idle valve or is idle controlled using ETB?
pierreroc
Post by pierreroc »
Hello and thanks for the proposal of 1UZFE VVTi control. The engine has electronic throttle so i assume that idle is regulated via the etb. For now i work on the chassis (lots of work ...) so work on the engine will be in 2020 but i will follow rusefi project and ask some questions to prepare my engine swap (currently a rover engine).
Thanks, have a good day.
Pierre.
