Page 1 of 2
Micro Rusefi for a Renault K4M engine #58
Posted: Fri Mar 13, 2020 8:04 pm
by JPh
My project is to tune a MRE for a K4M engine. The idea is to have a stand alone ECU for trackdays with its own loom and easyly go back to OEM for street use. I will share the steps I follow so perhaps readers will not have to search on the forum, wiki, github, slack channels to find some informations.
Re: Micro Rusefi for a Renault K4M engine
Posted: Fri Mar 13, 2020 8:10 pm
by JPh
First step : connect the MRE to tunerstudio.
Some problems with the drivers (see micro rusefi connection to tunerstudio
https://rusefi.com/forum/viewtopic.php?f=5&t=1671).
Now everything is working and some hours will be necessary to use all the features.
Re: Micro Rusefi for a Renault KM4 engine
Posted: Fri Mar 13, 2020 8:17 pm
by JPh
Next step : cut an OEM loom from a spare engine to make the mre one. Need it to calibrate the sensors and for the bench tests. With the mre connector it's easy to make.
Posted: Fri Mar 13, 2020 9:51 pm
JPh wrote: ↑Fri Mar 13, 2020 8:04 pm
I will share the steps I follow so perhaps readers will not have to search on the forum, wiki, github, slack channels to find some information.
We need more threads like this, thank you!
Posted: Fri Mar 13, 2020 10:33 pm
by JPh
You help me a lot making such a product available. Open source and co-desing are great!
Posted: Sat Mar 14, 2020 4:31 pm
by JPh
Today construction of the flywheel drive.
Why bother with hardware when we can simulate it?
Because real world signals learn you more about functioning, gap limits, voltage increase with rpm, sync loss...
I have all I need handy, so I jumped in.
À VR simulator is also on the list, I don't want to spin my heavy OEM wheel 10000 rpm...
When I will go for an aluminum flywheel, the different trigger wheel will also be worth a spin.
Posted: Sat Mar 21, 2020 4:10 pm
by JPh
It's running!
- 15848068282586754662431216785393.jpg (2.28 MiB) Viewed 22608 times
60 to 5000 rpm
Posted: Sat Mar 21, 2020 4:20 pm
JPh wrote: ↑Sat Mar 21, 2020 4:10 pm
60 to 5000 rpm
Can you safely go above 5000rpm?
Posted: Sat Mar 21, 2020 4:30 pm
by JPh
I'm limited by motor power, and fear getting the flywheel flying...
High rpm test will be done with function generator.
I will capture the signal at 5000 and feed the wave form in the generator and then go up in revs.
But I have to find an amplifier to get the right voltage level.
I will post a 60 and 5000 rpm sample for reference purpose.
Posted: Sat Mar 21, 2020 4:38 pm
Thank you for amazing content!
Posted: Sat Mar 21, 2020 4:51 pm
by JPh
I hope there be more to come!
Posted: Sat Mar 21, 2020 6:08 pm
by JPh
Here are the waveforms for low and high speed :
- slow speed.png (7.78 KiB) Viewed 22593 times
- high speed.png (7.95 KiB) Viewed 22593 times
If there are some data scientists in the community : attached the samplings corresponding.
Sensor gap 0,5mm.
Posted: Sun Mar 22, 2020 4:52 am
by mck1117
JPh wrote: ↑Sat Mar 21, 2020 6:08 pm
Sensor gap 0,5mm.
Signal looks great! Should do just fine with MRE.
Posted: Sun Mar 22, 2020 10:34 am
by JPh
Some data calculated from the above test :
Rpm 71 peak to peak 1,1v
Rpm 5555 peak to peak 88v
Posted: Sun Mar 22, 2020 2:21 pm
by dexter_lab
Looks VR by the book
the TLE8888 will handle it. It will be interesting to see how it look like when ignition is attached. Do you plan to simulate with hardware as well?
Posted: Sun Mar 22, 2020 8:28 pm
by JPh
Yes my MRE will be tested with hardware up to 5500 rpm.
From that point to max possible it will be tested with a signal generator.
Posted: Tue Mar 24, 2020 2:16 pm
by JPh
Now that injectors and coils are running, it will be time to test sync with spinner
Posted: Wed Mar 25, 2020 7:31 pm
by JPh
Not much time to test today.
First run the vr sensor was wired inverted : there were two big spikes on the fast logger with the shorter first. Mre worked with 60/2 trigger but timing was not on mark.
Inverted the vr wires spikes are in order after but 60/2 trigger didn't work anymore.
Switched to 60/2 vw had sync losses at low speed.
Need more research and work on the system.
Posted: Wed Mar 25, 2020 8:53 pm
by mck1117
JPh wrote: ↑Wed Mar 25, 2020 7:31 pm
What do you mean timing wasn't on mark? The trigger logger page in TS should show 58 short teeth, then one tooth that's 3 times the height. You also don't need to swap the wires - there's an option in the trigger input page to invert the trigger polarity.
Posted: Thu Mar 26, 2020 7:47 am
by JPh
To test I ran on fixed advance, setting it to 0.
I don't know what is 0 advance for rusefi.
On other systems it's during the large tooth and the next normal tooth is number 1.
During the different tests I made, the timing light showed a point in the large tooth, this point changed dured the different test I made.
But this was not the problem for me : the problem was with inverted vr 60/2 setting for trigger worked but shifted with rpm.
With normal vr wiring 60/2 stopped to work and 60/2 vw worked but only at high rpm. At slow rpm the mre lost sync randomly for a short moment an re synced and so on.
Posted: Thu Mar 26, 2020 7:20 pm
by JPh
After some more work and with Gwendal's help, mre is working now.
My problem was an operator's error. I mis interpreted TS fast logger : I thought that the mid long tooth followed by the long tooth was the sign of an inverted vr polarity. This was wrong, if inverted both 60/2 and 60/2 vw were no more working.
With a working sync I could check ignition accuracy.
First with an old timing light. I saw some stability problems that needed more checking. With the scopes, the problems disappeared so my timing light has triggering problems.
I decided to make a new test setup to have real world results. I know you cannot pick up the vr signal to sync the scope. There are common ground problems which make the ecu malfunction.
So I added an other vr sensor only for scope sync :
- IMG_20200326_182209.jpg (2.71 MiB) Viewed 22283 times
There is an angle between the two sensors, So I set the fixed ignition advance to 2 degrees which compensated this angle.
Here the résultats for different rpm :
750 rpm
- Image750.png (6.73 KiB) Viewed 22282 times
2500 rpm
- Image2500.png (5.96 KiB) Viewed 22282 times
4000 rpm
- Image4000.png (7.04 KiB) Viewed 22282 times
5700 rpm
- Image5700.png (7.25 KiB) Viewed 22282 times
For me these are very good results.
Posted: Thu Mar 26, 2020 8:42 pm
by mck1117
Looks great, that's a good test!
Posted: Sat Apr 04, 2020 3:42 pm
by JPh
This (sunny) afternoon, MRE found its place under the hood of the Secma F16.
It's just over the oem ecu, attached to the 4 ignition drivers who are clamp bolted to the frame tube.
The loom will be easy to route over the oem one and the ecu is on the cool side of the engine.
Posted: Sat Apr 04, 2020 5:31 pm
Posted: Sat Apr 04, 2020 6:31 pm
by JPh
Yes, so the USB cable won't be too long to log for tuning.
Posted: Sun Apr 05, 2020 2:38 am
by mck1117
Hey, that thing is just an 80% scale Lotus 340R!
Posted: Sun Apr 05, 2020 3:36 am
Nice.
Posted: Sun Apr 05, 2020 7:52 am
by JPh
Posted: Sun Apr 05, 2020 2:49 pm
I am not sure how reliable this would be without rusEfi stickers.
Posted: Sun Apr 05, 2020 3:57 pm
I understand the rusEFI sticker gives you an extra 10 HP.
