A V-twin Hello from Russia
Zhivoi
Post by Zhivoi »
Another hello from Russia!
Sorry for my bad english.
I am also from a small town near Moscow. Because of the virus, I got a lot of free time. Just starting to deal with this project.
I want to convert my carburatur V-twin motorcycle into injector system. So for me its hardware + software project.
I am programmer for embedded systems, STM32 too - so I think I can figure out the software part of the project.
AndreyB, I am interrested in MicroRusEFI, I saw them in ebay. I correctly understand that in order to assemble and test the system on the table, I need a RusEFI board, sensors, nozzles, coils and spark plugs? I got factory made injection module, with throttle position and MAF sensor, idle control. There is a hall sensor on the motorcycle, but only for 2 crankshaft positions, so I need to increase the number of positions (to how many?).
Re: A V-twin Hello from Russia
Zhivoi
Post by Zhivoi »
So, I got a board. I connected it to a computer and powered 12v, connected a tuner studio and set it up a bit.
Now I want to get the minimum functionality - connect the hall sensor, ignition coil and injector. And get this working on the table.
Now I have a lot of newbie questions:
1) I need a hall sensor with a signal level of about 12V?
2) I need an ignition coil with a built-in power unit to be controlled by a + 5V signal?
3) Need some power unit installed between the ECU and the injector?
Ask this guy he make all most same what you ...
He speaks Russia ...
https://rusefi.com/forum/viewtopic.php?f=4&t=1584&p=34063&hilit=Kavabanga#p34063
https://github.com/rusefi/rusefi/wiki/HOWTO_join_slack_channel could be better for these basic questions
