RascalGC8 93 impreza EJ18
RascalGC8
Post by RascalGC8 »
ej18 automatic
Re: RascalGC8 93 impreza
You've got style! How come I have not seen this car?!
Joel has stopped by and progress was made!
We found the ECU! It was located in the passenger footwell Miata NA6 style :)
ECU pinout wiring colors match the car so we at least have ECU pinout! But not a proper wiring diagram :(
We get power from ignition switch from pin E29#10. No +12v detected on "Control unit power supply" pin E29#13 so there might be some main relay somewhere.
Problem: internet says that 7 tooth looks like the left wheel at
in reality it looks more like
is that engine compression messing up the shape or is that a different wheel or is that some sort of rusEFI issue?
Sun Dec 06, 2020 5:47 am
How hard is it to get eyeballs on the trigger wheel?
If it's VR, try swapping the wires. That looks like a lazy falling edge on a VR sensor...
mck1117 wrote:
Sun Dec 06, 2020 5:50 am
Yes, VR on microRusEFI
Sun Dec 06, 2020 5:51 am
on MRE you can just tick the "inverted" box, it has no polarity unlike the max chips
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
13021AA100
Dron_Gus wrote:
Sun Dec 06, 2020 4:02 pm
that looks like the second wheel, on the right side of andrey's image
Re: RascalGC8 93 impreza EJ18
Wow, this car uses high-side main relay control? microRusEFI does not have an easy option so I've simply wires main relay to ignition switch. https://github.com/rusefi/hw_microRusEfi/issues/204
With only one VR channel on microRusEFI I had to add new "Subaru 7 without 6" trigger wheel shape. TODO https://github.com/rusefi/rusefi/issues/2073
Next step wiring in WBO and we will calibrate this unknown MAF against a known MAF.
Innovate shows either 7 or 22 - please fix that
You want a "GM 3bar" MAP sensor mounted somewhere under the hood.
Joel has just got himself a 2001 740. Do we know what's inside?
Should be an M60B40.
mck1117 wrote:
Tue Jun 22, 2021 12:44 am
wiki says 2001 is M62TUB44
https://en.wikipedia.org/wiki/BMW_M62#M62B44
what do we know about M62TUB44?
TUB engines add intake VANOS (vvt). Two, one per intake cam. Fixed exhaust cams.
