Build thread for a car I am working on
Euro imported 1995 W124 E220 Cabriolet 5 Speed Manual
Originally had n/a 2.2 M111. Has been swapped to M111.975 and turbocharged (supercharger removed)
When I got it, it had Split Second AIC2 on it with 2 extra injectors, ran like garbage. Lots of other bad wiring I removed/fixed.
Stock ecu is old school Siemens and it had the biodegradable wiring harness
It now has the wiring harness from an 02 SLK230 (plugs for bosch me 2.8) I chose this harness because its wired for coil on plug. Car is getting ETB, all the factory stuff.
I am running it with an MRE, and hoping we have a plug and play break out board to make my life easy, if not ill just hard wire it to the mre pigtail.
Ill add pics and stuff here soon.
Turbo is gtx3576 replica, bosch 440cc green giants, bosch 044 pump.
