Page 2 of 2
Re: Pps not reading in Tunerstudio
Posted: Fri Feb 03, 2023 8:31 pm
Posted: Fri Feb 03, 2023 10:13 pm
by Slim804
I am as well...
Posted: Sat Feb 04, 2023 12:10 am
by bill
when you put the voltmeter on the signal wires from the pedal
with 5V and ground supplied to pedal
and move the pedal up and down
what are the voltages output on the wires?
0.5 to 3.5V on one output?
and
4.5 to 0.5 V on the second output?
that is normal for most bosch units
Posted: Sat Feb 04, 2023 12:18 am
by Slim804
When I put the multimeter on the wires, I'm getting 2.38 on the primary at full throttle and 4.68 on the secondary at full throttle
Posted: Sat Feb 04, 2023 12:21 am
Are you comfortable detaching PCB from rear cover and poking DMM into corresponding pin to check voltage on pin?
Did you crimp or was it a pigtail?
Posted: Sat Feb 04, 2023 12:26 am
by Slim804
I did not crimp anything as i wanted to be sure things were working properly before crimping. Im not completely sure what all is involved in that process
Posted: Sat Feb 04, 2023 12:35 am
huh? how are your wires connector to MRE? please post more pictures
Posted: Sat Feb 04, 2023 12:38 am
by Slim804
Just twisted together at the moment
Posted: Sat Feb 04, 2023 12:44 am
Oh now I see that you use MRE pigtail. Still same question - are you comfortable poking into back side of PCB with rear plate removed?
I am kind of running out of ideas
Posted: Sat Feb 04, 2023 12:46 am
by Slim804
I'll take it off and take a look back there
Posted: Sat Feb 04, 2023 1:01 am
by bill
Slim804 wrote: ↑Sat Feb 04, 2023 12:18 am
sounds correct.
and around 0.5V on each when the pedal is at idle?
Posted: Sat Feb 04, 2023 2:22 am
by Slim804
correct
Posted: Sat Feb 04, 2023 2:32 am
by Slim804
Detached the PCB from rear cover and poked DMM into corresponding pin. Im getting the same voltage at the pins that I was getting at the wires on the pigtail.
Posted: Sat Feb 04, 2023 3:01 am
i have a feeling that it's time to ship this unit to NJ
Posted: Sat Feb 04, 2023 3:08 am
by Slim804
Ok,Just let me know when and where to ship. I'm located in Virginia.
Posted: Mon Feb 13, 2023 7:24 pm
Someone else has hit same AV4 drama and we have a theory now, stay tuned!
https://github.com/rusefi/hw_microRusEfi/issues/231
Posted: Thu Feb 16, 2023 12:38 am
Just removed D7 please PM me your address for return!
Posted: Sat Mar 04, 2023 12:58 am
If it still does not work type to unbolt from case and poke into pins on the back of the PCB, just be careful. Time to tipple-check if voltage gets all the way to PCB.
Posted: Sat Mar 11, 2023 10:09 am
by mi-hol
@slim804
https://wiki.rusefi.com/HOWTO-M111-on-microRusEFI/#howto-m111-on-microrusefi contains
"Important suggestion: use Honda accelerator pedal position sensor (PPS) in the engine bay not Mercedes pedal position sensor"
no reason is given for this advise but I wonder if that is related to your issue
Posted: Sun Mar 12, 2023 5:26 am
mi-hol wrote: ↑Sat Mar 11, 2023 10:09 am
Jimmy says Mercedes sensors are pretty unreliable.
Posted: Sun Mar 12, 2023 12:21 pm
by mi-hol
AndreyB wrote: ↑Sun Mar 12, 2023 5:26 am
none of the many car sensors is actually manufactured by the car companies themselves.
Nearly all parts have a dual supplier (or at least dual factory) strategy in order to avoid supplier lock-in.
In a given car model identical parts are coming from different supplier therefore.
When a part has a failure rate above a given percentage the supplier is reviewed and eventually banned.
Above very broad statement is not really helping to address the root cause.
Root cause is most often something like: sensor from supplier A manufactured in week n of year Y in factory F fails prematurely due to tooling issue.
I was working for a Mercedes supplier some years ago.
Posted: Thu Mar 30, 2023 2:40 am
by Slim804
Ok I’ll take a look into that because as of right now I’m still fighting this issue
Posted: Mon May 08, 2023 8:03 pm
by bombaym111
Hi you everybody so someone can tell me how can I fix the Pedal position in tuner studio when i choose the right pin like 1er 31 and 2sec 30, not working still ERROR config Bye the way I use the lastes bandle thanks
Rusefi micro 0.6 version
