P0302 error code indicates that cylinder two is misfiring and not receiving enough spark to its spark plug.
Having fun with oscilloscope compression check - with spark plugs cranking with signal disconnected
Re: 2014 kia rio 1.6 GDI M/T busted dreams
Posted: Fri Apr 28, 2023 7:11 pm
These were brand new 40 miles ago. 1 and 2 look same kind of cleanest, 4 is by far the dirtiest. No 2 and 3 COPs are brand new so hopefully not COP issue on No 2. Clogged injector maybe?
All gaps are more or less 1mm, no 4 gap is not huge like it seems on the pic.
Ordered compression tested 12mm adapter.
Re: 2014 red kia rio 1.6 GDI M/T busted dreams
Posted: Wed May 03, 2023 4:13 am
TL,DR: stuck rings on cylinder #2? maybe thermostat? yes I am hoping it's not head gasket.
Open question why I am trying to fix it but it's kind of fun and relaxing.
Two symptoms: P0302 misfire cylinder 2 code, and on my way home it has overheated on the highway. Changing gear/lowing RPM has lowered temperature and allowed me to get home.
Let's focus on misfire cylinder 2 for now.
Dry compression test results: 130/70/120/120
Wet compression test results: 200/200/200/200
WOW, does this clearly point at rings not blown HG?
Put 100gm of diesel and 100gm of ATF into cylinder two. Will let it sit for 24 hours.
Obviously I do not have patience for 24 hours. Bumped starter just to move things 9 hours into the soaking and added more liquid. With total 18 hours of soaking I've cranked for a bit and then drove around the block.
WOW?! No check engine so far?! 120 compression?!
Posted: Sat May 13, 2023 2:39 pm
Pictured different kia GDI harness - I've noted the twisted wires. Also a bit of tape to hold the twist in place?
Posted: Fri Jun 09, 2023 8:58 pm
Looks like 4 lobes?
dark blue trace is cam sensor
yellow trace is white HPFP wire
light blue is brown HPFP wire
Posted: Mon Jun 12, 2023 12:49 am
Posted: Mon Jun 12, 2023 4:01 am
HPFP coil resistance is 0.5ohm
Ohms Law says 24A if that would be continuous flow.
GDI4 defaults for pump control are peak 5A hold 3A, I wonder if this pump wants above default values?
Yesterday i definitely had high pressure. with manual hack/control pump clicks were pretty loud
today pressure does not build. same 0.5 ohm on the pump solenoid, with manual control it makes a very quiet humming noise. actually let me double-check pump current settings
