Does it have pn? I mean I have a lot of different noname sensors from eBay and Aliexpress.
But if you know some good quality OEM sensor - I'd better spend some $ buying it.
Ahh I understand, the once I have comes from the development side of a big Swedish car manufacturer
I guess they are pretty expensive, and only markings are Pentronic and a phone number, sorry.
I have discoverred one thing, you can't have a grounding one if you want to measure something conductive that is grounded (exhaust system).
You need a isolated one (the cheap eBay ones I have isn't).
Also EGT are pron to pickup EMI there for I should switch to a shielded one.
Yes, I think Pentronic AB produce good stuff Sensor is quite small, looking at your logs it has good response time.
Thanks for hints. Sensors from Ali comes with shielded wires, but I did not check if it isolated. I'll check.
BTW, do you still have issue with LIS2D?
Re: 1987 Volvo 780
Posted: Tue Feb 06, 2024 1:42 pm
by zed65
I've not tested LIS2D yet, I'm waiting on my latest board for that. But if I understand it correct it 'should' work.
Where are you located? Maybe I can send one of my spares to you with a bung and everything.
Re: 1987 Volvo 780
Posted: Tue Feb 06, 2024 9:46 pm
by zed65
Note to myself, this is my current pin-out to the ECU
Ok. Let me know if you have some troubles with LIS.
It is not a good idea to send me anything. Couse I'm located in Saint-Petersburg, Russia. But anyway thanks for offering.
