Posts: 14752 Joined: Wed Aug 28, 2013 1:28 am
Post
by AndreyB » Thu May 09, 2024 4:43 pm
Many years ago I had a not so bright orange vehicle with a Honda K engine. It has blown the head gasket for not good reason
So I've decided to purchase a bright orange vehicle, again with Honda K engine, this time GDI and turbo-charged! And Acura Care Extended Warranty
Post
by AndreyB » Tue May 21, 2024 2:27 am
Active Dumper System, the less fancy one without stroke sensors like on Civic Type R.
Why do they run two dedicated wires to each strut solenoid? Why not shared high side?
Posts: 1501 Joined: Mon Jan 30, 2017 2:05 am
Post
by mck1117 » Tue May 21, 2024 7:47 am
AndreyB wrote: ↑ Tue May 21, 2024 2:27 am
look at a modern engine harness too, OEMs avoid splices like the plague if they can
Posts: 2963 Joined: Mon Nov 11, 2013 11:28 am
Post
by puff » Tue May 21, 2024 7:52 pm
mck1117 wrote: ↑ Tue May 21, 2024 7:47 am
but what's the reason? to simplify diagnostics?
Post
by mck1117 » Mon Jul 08, 2024 6:12 pm
puff wrote: ↑ Tue May 21, 2024 7:52 pm
Splices are less reliable than running a separate wire to the ECU. Splices are probably actually more expensive too, since they need an extra step of joining multiple wires together, rather than just "wire with something crimped either end" which you can automate.
Post
by AndreyB » Tue Aug 06, 2024 12:10 am
I think it uses an NTK wideband so we have a chance to poke into a running vehicle
Internet says
Blue = Heater +
Yellow = Heater -
Grey Wire = Vs
White Wire = Ion Pump
Black Wire = 0v
My multimeter says 3.5Ohm between blue and yellow, and I have a patch cord ready for poking
