Hi all. I'm "Rocketman" I hail from the NorthEast USA
I'm sort of a jack of all trades. Woodworking, metalcasting, machining, mechanic, computer junkie, etc. Little bit of everything.
I have worked with mazda MECS ecu's in the past as well as some MS stuff, anxious to get my feet wet here.
I'll see what I can do to help further this project. Glad to be here.
-Rocketman
Howdy
Re: Howdy
Welcome, rocketman! Glad to see you here.
Re: Howdy
NorthEast you say. I'm a Maine-ack (pronounced maniac) I work in NH, but often commute to Mass. Are you in my neck of the hundred ache woods?
Also welcome along.
Also welcome along.
Re: Howdy
Not quite that northeast! I'm in eastern PA, close to the NJ border in the I-80 corridor. I was up in Maine over the summer, quite nice up there! Not sure if I'd want to weather a winter there though, they're bad enough in PA - I need south not north
Jack of all trades, master of none.
Re: Howdy
Hi Rocketman.
It sounds like you have the perfect skills set!
This looks like a great solution. http://www.werbatfik.com/ecu.htm
It would be so nice if all stock ecus came with a similar socket.
Mognerm Werbatfik
Mognerm Werbatfik
Re: Howdy
The first rule of this project: nothing is official in this project.
Re: Howdy
But yes.
