[rusEfi] Mitsubishi 4G63 and 4G92 (#6)
Re: Mitsubishi 4G63 and 4G92 (#6)
Tambralinga wrote:If my hall sensor input primary input channel PC6 and secondary input channel PA5.
I can setting speed sensor PC6 or PA5?
No.
If you are using PC6 and PA5 for shaft position sensors, you need to use something else for VSS. PA8 for example is one of the options, but you would need to wire the signal through op-amp, same way as shaft sensors are wired.
Tambralinga
Post by Tambralinga »
CLT GPIO PC3
 Low temp 20
 Resistor 2500
 middel Temp 23.9
 resistor 2080
 Hi temp 80
 resistor 300
IAT GPIO PA1
 Low temp 8.9
 Resistor 7000
 middel Temp 30.6
 resistor 1930
 Hi temp 63
 resistor 560
Crank coolant temp
          Coolant           Correction
             -18	             160
              -7	             150
               4	             135
              16	             125
              27	             116
              38	             108
              54	             102
              71	             100
TPS	PC1
CLT	PC3
IAT	PA1
MAP	PA4
ARF	PC4
Fan	PE0
Pump	PC13
FSIO	PE1
Injection Pin1	PB9
Injection Pin2	PB8
Injection Pin3	PE3
Injection Pin4	PE5
Ignition Pin1	PE14
Ignition Pin2	NONE
Ignition Pin3	PE12
Ignition Pin4	NONE
Pls change new config for mitsubishi and Trigger type Miata NA
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:Pls change new config
"change" or "new"?
Are we changing existing config or creating a new config so that there are two different Mitsubishi configs?
Tambralinga
"change" or "new"?
Edited from the original.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
I want to know if the protocal between TS with STM 32 to find out from where?
Skype : shiva-p
+66 8 5357 5159
Sorry I have not hard-coded your config yet :(
There are some comments on top of the source code files,
Most comments are in https://svn.code.sf.net/p/rusefi/code/trunk/firmware/console/binary/tunerstudio_io.cpp
also something in https://svn.code.sf.net/p/rusefi/code/trunk/firmware/console/binary/tunerstudio.cpp
Tambralinga
russian wrote:Sorry I have not hard-coded your config yet :(
You have protocol for dev console?
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:You have protocol for dev console?
dev console is now using the same protocol
Tambralinga
Hello.
I came back after long gone.
How far is the development?
can use old config?
Skype : shiva-p
+66 8 5357 5159
Tambralinga
I don't know knock sensor freq override for mitsubish 4g93
firmware 20180401
set_engine_16 fatail error HW timer
Skype : shiva-p
+66 8 5357 5159
Not many changes, old engine types should work. CJ125 by @ is the most important progress recently.
Just added missing parameter to make knock band configurable - https://github.com/rusefi/rusefi/commit/c757009065f35c2eb3b8047cc31ee160201b21a2
fatail error HW timer can you reproduce this or is this a one time thing? Can you get me steps to reproduce reliably?
Tambralinga
error after set_engine_type 16
2018-05-21 19_00: EngineState: confirmation_set_engine_type 16:18
2018-05-21 19_00: EngineState: unknown [set_engine_type 16]
2018-05-21 19_00: EngineState: 140 actions available
2018-05-21 19_00: EngineState:   pins: 0 parameters
2018-05-21 19_00: EngineState:   help: 0 parameters
2018-05-21 19_00: EngineState:   echo: 1 parameters
2018-05-21 19_00: EngineState:   ~: 0 parameters
2018-05-21 19_00: EngineState:   test: 0 parameters
2018-05-21 19_00: EngineState:   hello: 0 parameters
2018-05-21 19_00: EngineState:   fatal: 0 parameters
2018-05-21 19_00: EngineState:   error: 0 parameters
2018-05-21 19_00: EngineState:   threadsinfo: 0 parameters
2018-05-21 19_00: EngineState:   reboot: 0 parameters
2018-05-21 19_00: EngineState:   readconfig: 0 parameters
2018-05-21 19_00: EngineState:   writeconfig: 0 parameters
2018-05-21 19_00: EngineState:   burnconfig: 0 parameters
2018-05-21 19_00: EngineState:   resetconfig: 0 parameters
2018-05-21 19_00: EngineState:   rewriteconfig: 0 parameters
2018-05-21 19_00: EngineState:   lcdinfo: 0 parameters
2018-05-21 19_00: EngineState:   adcdebug: 1 parameters
2018-05-21 19_00: EngineState:   adc: 1 parameters
2018-05-21 19_00: EngineState:   egtinfo: 0 parameters
2018-05-21 19_00: EngineState:   egtread: 0 parameters
2018-05-21 19_00: EngineState:   caninfo: 0 parameters
2018-05-21 19_00: EngineState:   chartsize: 1 parameters
2018-05-21 19_00: EngineState:   chart: 1 parameters
2018-05-21 19_00: EngineState:   reset_engine_chart: 0 parameters
2018-05-21 19_00: EngineState:   triggerinfo: 0 parameters
2018-05-21 19_00: EngineState:   trigger_shape_info: 0 parameters
2018-05-21 19_00: EngineState:   reset_trigger: 0 parameters
2018-05-21 19_00: EngineState:   hipinfo: 0 parameters
2018-05-21 19_00: EngineState:   set_gain: 1 parameters
2018-05-21 19_00: EngineState:   set_band: 1 parameters
2018-05-21 19_00: EngineState:   set_hip_prescalerandsdo: 1 parameters
2018-05-21 19_00: EngineState:   set_knock_threshold: 1 parameters
2018-05-21 19_00: EngineState:   set_max_knock_sub_deg: 1 parameters
2018-05-21 19_00: EngineState:   sdinfo: 0 parameters
2018-05-21 19_00: EngineState:   mountsd: 0 parameters
2018-05-21 19_00: EngineState:   appendtolog: 1 parameters
2018-05-21 19_00: EngineState:   umountsd: 0 parameters
2018-05-21 19_00: EngineState:   ls: 1 parameters
2018-05-21 19_00: EngineState:   del: 1 parameters
2018-05-21 19_00: EngineState:   incfilename: 0 parameters
2018-05-21 19_00: EngineState:   i2c: 2 parameters
2018-05-21 19_00: EngineState:   speedinfo: 0 parameters
2018-05-21 19_00: EngineState:   joystickinfo: 0 parameters
2018-05-21 19_00: EngineState:   fl: 1 parameters
2018-05-21 19_00: EngineState:   warn: 1 parameters
2018-05-21 19_00: EngineState:   fuelinfo2: 2 parameters
2018-05-21 19_00: EngineState:   fuelinfo: 0 parameters
2018-05-21 19_00: EngineState:   set_led_blinking_period: 1 parameters
2018-05-21 19_00: EngineState:   status: 0 parameters
2018-05-21 19_00: EngineState:   analoginfo: 0 parameters
2018-05-21 19_00: EngineState:   set_float: 2 parameters
2018-05-21 19_00: EngineState:   set_int: 2 parameters
2018-05-21 19_00: EngineState:   set_short: 2 parameters
2018-05-21 19_00: EngineState:   set_bit: 3 parameters
2018-05-21 19_00: EngineState:   get_float: 1 parameters
2018-05-21 19_00: EngineState:   get_int: 1 parameters
2018-05-21 19_00: EngineState:   get_short: 1 parameters
2018-05-21 19_00: EngineState:   get_bit: 2 parameters
2018-05-21 19_00: EngineState:   set_sensor_chart_freq: 1 parameters
2018-05-21 19_00: EngineState:   showconfig: 0 parameters
2018-05-21 19_00: EngineState:   tempinfo: 0 parameters
2018-05-21 19_00: EngineState:   tpsinfo: 0 parameters
2018-05-21 19_00: EngineState:   info: 0 parameters
2018-05-21 19_00: EngineState:   set_one_coil_ignition: 0 parameters
2018-05-21 19_00: EngineState:   set_wasted_spark_ignition: 0 parameters
2018-05-21 19_00: EngineState:   set_individual_coils_ignition: 0 parameters
2018-05-21 19_00: EngineState:   set_whole_phase_map: 1 parameters
2018-05-21 19_00: EngineState:   set_whole_timing_map: 1 parameters
2018-05-21 19_00: EngineState:   set_whole_fuel_map: 1 parameters
2018-05-21 19_00: EngineState:   set_whole_ve_map: 1 parameters
2018-05-21 19_00: EngineState:   set_whole_ign_corr_map: 1 parameters
2018-05-21 19_00: EngineState:   set_fuel_map: 3 parameters
2018-05-21 19_00: EngineState:   set_timing_map: 3 parameters
2018-05-21 19_00: EngineState:   stopengine: 0 parameters
2018-05-21 19_00: EngineState:   enable_spi: 1 parameters
2018-05-21 19_00: EngineState:   disable_spi: 1 parameters
2018-05-21 19_00: EngineState:   enable: 1 parameters
2018-05-21 19_00: EngineState:   disable: 1 parameters
2018-05-21 19_00: EngineState:   set_toothed_wheel: 2 parameters
2018-05-21 19_00: EngineState:   set_flat_injector_lag: 1 parameters
2018-05-21 19_00: EngineState:   set_injector_lag: 2 parameters
2018-05-21 19_00: EngineState:   set_fan: 2 parameters
2018-05-21 19_00: EngineState:   set: 2 parameters
2018-05-21 19_00: EngineState:   get: 1 parameters
2018-05-21 19_00: EngineState:   showpin: 1 parameters
2018-05-21 19_00: EngineState:   set_injection_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_ignition_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_trigger_input_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_trigger_simulator_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_egt_cs_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_egt_spi: 1 parameters
2018-05-21 19_00: EngineState:   set_trigger_simulator_mode: 2 parameters
2018-05-21 19_00: EngineState:   set_fuel_pump_pin: 1 parameters
2018-05-21 19_00: EngineState:   set_ac_pin: 1 parameters
2018-05-21 19_00: EngineState:   set_alternator_pin: 1 parameters
2018-05-21 19_00: EngineState:   set_idle_pin: 1 parameters
2018-05-21 19_00: EngineState:   set_main_relay_pin: 1 parameters
2018-05-21 19_00: EngineState:   set_analog_input_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_logic_input_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_pot_spi: 1 parameters
2018-05-21 19_00: EngineState:   tsinfo: 0 parameters
2018-05-21 19_00: EngineState:   reset_ts: 0 parameters
2018-05-21 19_00: EngineState:   set_ts_speed: 1 parameters
2018-05-21 19_00: EngineState:   test_clt_by_r: 1 parameters
2018-05-21 19_00: EngineState:   mapinfo: 0 parameters
2018-05-21 19_00: EngineState:   set_fsio_pid_output_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_fsio_output_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_fsio_output_frequency: 2 parameters
2018-05-21 19_00: EngineState:   set_fsio_input_pin: 2 parameters
2018-05-21 19_00: EngineState:   set_rpn_expression: 2 parameters
2018-05-21 19_00: EngineState:   set_fsio_setting: 2 parameters
2018-05-21 19_00: EngineState:   fsioinfo: 0 parameters
2018-05-21 19_00: EngineState:   rpn_eval: 1 parameters
2018-05-21 19_00: EngineState:   accelinfo: 0 parameters
2018-05-21 19_00: EngineState:   binarytest: 0 parameters
2018-05-21 19_00: EngineState:   waveinfo: 0 parameters
2018-05-21 19_00: EngineState:   set_logic_input_mode: 2 parameters
2018-05-21 19_00: EngineState:   injector: 2 parameters
2018-05-21 19_00: EngineState:   fuelpumpbench: 0 parameters
2018-05-21 19_00: EngineState:   fuelpumpbench2: 1 parameters
2018-05-21 19_00: EngineState:   fanbench: 0 parameters
2018-05-21 19_00: EngineState:   fanbench2: 1 parameters
2018-05-21 19_00: EngineState:   dizzybench: 0 parameters
2018-05-21 19_00: EngineState:   milbench: 0 parameters
2018-05-21 19_00: EngineState:   fuelbench: 3 parameters
2018-05-21 19_00: EngineState:   sparkbench: 3 parameters
2018-05-21 19_00: EngineState:   fuelbench2: 5 parameters
2018-05-21 19_00: EngineState:   sparkbench2: 5 parameters
2018-05-21 19_00: EngineState:   altinfo: 0 parameters
2018-05-21 19_00: EngineState:   ethinfo: 0 parameters
2018-05-21 19_00: EngineState:   faststat: 0 parameters
2018-05-21 19_00: EngineState:   performanceinfo: 0 parameters
2018-05-21 19_00: EngineState:   maininfo: 0 parameters
2018-05-21 19_00: EngineState:   idleinfo: 0 parameters
2018-05-21 19_00: EngineState:   blipidle: 2 parameters
2018-05-21 19_00: EngineState:   idlebench: 0 parameters
2018-05-21 19_00: EngineState:   reset_accel: 0 parameters
2018-05-21 19_00: EngineState:   rpm: 1 parameters
2018-05-21 19_00: EngineState:   stop_stimulator_at_index: 1 parameters
2018-05-21 19_00: EngineState:   resume_stimulator: 0 parameters
2018-05-21 19_00: EngineState: For more visit http://rusefi.com/wiki/index.php?title=Manual:Software:dev_console_commands
2018-05-21 19_00: EngineState: error: synchronizationPoint @ index 3 expected 2/2/0 got 4/0/0
Skype : shiva-p
+66 8 5357 5159
Tambralinga
step 1 erase chip
step 2 program new firmware
error ERROR: CRC header size
EngineState: FATAL error: HW timer state 1
2018-05-23 13_15: CommandQueue: SerialIO started
2018-05-23 13_15: SerialManager: Opening port: COM5
2018-05-23 13_15: EngineState: WARNING: flash CRC failed
2018-05-23 13_15: EngineState: applyNonPersistentConfiguration()
2018-05-23 13_15: EngineState: initializeTriggerShape(TT_ONE_PLUS_ONE/16)
2018-05-23 13_15: EngineState: *** rusEFI (c) Andrey Belomutskiy 2012-2017. All rights reserved.
2018-05-23 13_15: EngineState: rusEFI v20180401@15715
2018-05-23 13_15: EngineState: *** Chibios Kernel:       4.0.3
2018-05-23 13_15: EngineState: *** Compiled:     May 20 2018 - 15:55:54
2018-05-23 13_15: EngineState: COMPILER=6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
2018-05-23 13_15: EngineState: CORTEX_MAX_KERNEL_PRIORITY=2
2018-05-23 13_15: EngineState: STM32_ADCCLK=21000000
2018-05-23 13_15: EngineState: STM32_TIMCLK1=84000000
2018-05-23 13_15: EngineState: STM32_TIMCLK2=168000000
2018-05-23 13_15: EngineState: STM32_PCLK1=42000000
2018-05-23 13_15: EngineState: STM32_PCLK2=84000000
2018-05-23 13_15: EngineState: PORT_IDLE_THREAD_STACK_SIZE=1024
2018-05-23 13_15: EngineState: CH_DBG_ENABLE_ASSERTS=1
2018-05-23 13_15: EngineState: CH_DBG_SYSTEM_STATE_CHECK=1
2018-05-23 13_15: EngineState: CH_DBG_ENABLE_STACK_CHECK=1
2018-05-23 13_15: EngineState: EFI_WAVE_ANALYZER=1
2018-05-23 13_15: EngineState: EFI_TUNER_STUDIO=1
2018-05-23 13_15: EngineState: EFI_SIGNAL_EXECUTOR_SLEEP=0
2018-05-23 13_15: EngineState: EFI_SIGNAL_EXECUTOR_HW_TIMER=0
2018-05-23 13_15: EngineState: EFI_SHAFT_POSITION_INPUT=1
2018-05-23 13_15: EngineState: EFI_INTERNAL_ADC=1
2018-05-23 13_15: EngineState: led: ERROR status on PD14
2018-05-23 13_15: EngineState: lcd RS on PE7
2018-05-23 13_15: EngineState: lcd E on PE9
2018-05-23 13_15: EngineState: lcd DB4 on PE11
2018-05-23 13_15: EngineState: lcd DB5 on PE13
2018-05-23 13_15: EngineState: lcd DB6 on PE15
2018-05-23 13_15: EngineState: lcd DB7 on PB10
2018-05-23 13_15: EngineState: board test on PB0
2018-05-23 13_15: EngineState: adc input on PA0
2018-05-23 13_15: EngineState: adc input on PA2
2018-05-23 13_15: EngineState: adc input on PC0
2018-05-23 13_15: EngineState: adc input on PC1
2018-05-23 13_15: EngineState: adc input on PC2
2018-05-23 13_15: EngineState: adc input on PC3
2018-05-23 13_15: EngineState: adc input on PC4
2018-05-23 13_15: EngineState: spi CS5 on PD4
2018-05-23 13_15: EngineState: fuel pump relay on PE4
2018-05-23 13_15: EngineState: main relay on PD7
2018-05-23 13_15: EngineState: fan relay on PE5
2018-05-23 13_15: EngineState: CAN TX on PB6
2018-05-23 13_15: EngineState: CAN RX on PB12
2018-05-23 13_15: EngineState: engine chart: Yes
2018-05-23 13_15: EngineState: engine chart size=300
2018-05-23 13_15: EngineState: trigger#1 on PC6
2018-05-23 13_15: EngineState: turnOnTriggerInputPin PC6
2018-05-23 13_15: EngineState: trigger#2 on PA5
2018-05-23 13_15: EngineState: turnOnTriggerInputPin PA5
2018-05-23 13_15: EngineState: SPI clock on PB13
2018-05-23 13_15: EngineState: SPI master out on PB15
2018-05-23 13_15: EngineState: SPI master in  on PB14
2018-05-23 13_15: EngineState: SPI clock on PB3
2018-05-23 13_15: EngineState: SPI master out on PB5
2018-05-23 13_15: EngineState: SPI master in  on PB4
2018-05-23 13_15: EngineState: hip int/hold on PB11
2018-05-23 13_15: EngineState: hip CS on PB0
2018-05-23 13_15: EngineState: Starting HIP9011/TPIC8101 driver
2018-05-23 13_15: EngineState: joy center on PC8
2018-05-23 13_15: EngineState: joy A on PD10
2018-05-23 13_15: EngineState: joy D on PD11
2018-05-23 13_15: EngineState: i1 on PB9
2018-05-23 13_15: EngineState: i2 on PE2
2018-05-23 13_15: EngineState: i3 on PB8
2018-05-23 13_15: EngineState: i4 on PB7
2018-05-23 13_15: EngineState: c1 on PE14
2018-05-23 13_15: EngineState: c2 on PC7
2018-05-23 13_15: EngineState: c3 on PC9
2018-05-23 13_15: EngineState: c4 on PE10
2018-05-23 13_15: EngineState: injector_1: 1
2018-05-23 13_15: EngineState: injector_2: 1
2018-05-23 13_15: EngineState: injector_3: 1
2018-05-23 13_15: EngineState: injector_4: 1
2018-05-23 13_15: EngineState: led: comm status on PD15
2018-05-23 13_15: EngineState: led: warning status on PD13
2018-05-23 13_15: EngineState: led: running status on PD12
2018-05-23 13_15: EngineState: FATAL error: HW timer state 1
2018-05-23 13_15: EngineState: TS: ERROR: no second byte
2018-05-23 13_15: EngineState: TunerStudio size=356 / total=0 / errors=0 / H=0 / O=0 / P=0 / B=0
2018-05-23 13_15: EngineState: TunerStudio W=0 / C=0 / P=0 / page=0
after set set_engine_type 16
2018-05-23 13_40: EngineState: confirmation_set_engine_type 16:18
2018-05-23 13_40: EngineState: unknown [set_engine_type 16]
2018-05-23 13_40: EngineState: 115 actions available
2018-05-23 13_40: EngineState:   pins: 0 parameters
2018-05-23 13_40: EngineState:   help: 0 parameters
2018-05-23 13_40: EngineState:   echo: 1 parameters
2018-05-23 13_40: EngineState:   ~: 0 parameters
2018-05-23 13_40: EngineState:   test: 0 parameters
2018-05-23 13_40: EngineState:   hello: 0 parameters
2018-05-23 13_40: EngineState:   fatal: 0 parameters
2018-05-23 13_40: EngineState:   error: 0 parameters
2018-05-23 13_40: EngineState:   threadsinfo: 0 parameters
2018-05-23 13_40: EngineState:   reboot: 0 parameters
2018-05-23 13_40: EngineState:   readconfig: 0 parameters
2018-05-23 13_40: EngineState:   writeconfig: 0 parameters
2018-05-23 13_40: EngineState:   burnconfig: 0 parameters
2018-05-23 13_40: EngineState:   resetconfig: 0 parameters
2018-05-23 13_40: EngineState:   rewriteconfig: 0 parameters
2018-05-23 13_40: EngineState:   lcdinfo: 0 parameters
2018-05-23 13_40: EngineState:   adcdebug: 1 parameters
2018-05-23 13_40: EngineState:   adc: 1 parameters
2018-05-23 13_40: EngineState:   egtinfo: 0 parameters
2018-05-23 13_40: EngineState:   egtread: 0 parameters
2018-05-23 13_40: EngineState:   caninfo: 0 parameters
2018-05-23 13_40: EngineState:   chartsize: 1 parameters
2018-05-23 13_40: EngineState:   chart: 1 parameters
2018-05-23 13_40: EngineState:   reset_engine_chart: 0 parameters
2018-05-23 13_40: EngineState:   triggerinfo: 0 parameters
2018-05-23 13_40: EngineState:   trigger_shape_info: 0 parameters
2018-05-23 13_40: EngineState:   reset_trigger: 0 parameters
2018-05-23 13_40: EngineState:   hipinfo: 0 parameters
2018-05-23 13_40: EngineState:   set_gain: 1 parameters
2018-05-23 13_40: EngineState:   set_band: 1 parameters
2018-05-23 13_40: EngineState:   set_hip_prescalerandsdo: 1 parameters
2018-05-23 13_40: EngineState:   set_knock_threshold: 1 parameters
2018-05-23 13_40: EngineState:   set_max_knock_sub_deg: 1 parameters
2018-05-23 13_40: EngineState:   sdinfo: 0 parameters
2018-05-23 13_40: EngineState:   mountsd: 0 parameters
2018-05-23 13_40: EngineState:   appendtolog: 1 parameters
2018-05-23 13_40: EngineState:   umountsd: 0 parameters
2018-05-23 13_40: EngineState:   ls: 1 parameters
2018-05-23 13_40: EngineState:   del: 1 parameters
2018-05-23 13_40: EngineState:   incfilename: 0 parameters
2018-05-23 13_40: EngineState:   i2c: 2 parameters
2018-05-23 13_40: EngineState:   speedinfo: 0 parameters
2018-05-23 13_40: EngineState:   joystickinfo: 0 parameters
2018-05-23 13_40: EngineState:   fl: 1 parameters
2018-05-23 13_40: EngineState:   warn: 1 parameters
2018-05-23 13_40: EngineState:   fuelinfo2: 2 parameters
2018-05-23 13_40: EngineState:   fuelinfo: 0 parameters
2018-05-23 13_40: EngineState:   set_led_blinking_period: 1 parameters
2018-05-23 13_40: EngineState:   status: 0 parameters
2018-05-23 13_40: EngineState:   analoginfo: 0 parameters
2018-05-23 13_40: EngineState:   set_float: 2 parameters
2018-05-23 13_40: EngineState:   set_int: 2 parameters
2018-05-23 13_40: EngineState:   set_short: 2 parameters
2018-05-23 13_40: EngineState:   set_bit: 3 parameters
2018-05-23 13_40: EngineState:   get_float: 1 parameters
2018-05-23 13_40: EngineState:   get_int: 1 parameters
2018-05-23 13_40: EngineState:   get_short: 1 parameters
2018-05-23 13_40: EngineState:   get_bit: 2 parameters
2018-05-23 13_40: EngineState:   set_sensor_chart_freq: 1 parameters
2018-05-23 13_40: EngineState:   showconfig: 0 parameters
2018-05-23 13_40: EngineState:   tempinfo: 0 parameters
2018-05-23 13_40: EngineState:   tpsinfo: 0 parameters
2018-05-23 13_40: EngineState:   info: 0 parameters
2018-05-23 13_40: EngineState:   set_one_coil_ignition: 0 parameters
2018-05-23 13_40: EngineState:   set_wasted_spark_ignition: 0 parameters
2018-05-23 13_40: EngineState:   set_individual_coils_ignition: 0 parameters
2018-05-23 13_40: EngineState:   set_whole_phase_map: 1 parameters
2018-05-23 13_40: EngineState:   set_whole_timing_map: 1 parameters
2018-05-23 13_40: EngineState:   set_whole_fuel_map: 1 parameters
2018-05-23 13_40: EngineState:   set_whole_ve_map: 1 parameters
2018-05-23 13_40: EngineState:   set_whole_ign_corr_map: 1 parameters
2018-05-23 13_40: EngineState:   set_fuel_map: 3 parameters
2018-05-23 13_40: EngineState:   set_timing_map: 3 parameters
2018-05-23 13_40: EngineState:   stopengine: 0 parameters
2018-05-23 13_40: EngineState:   enable_spi: 1 parameters
2018-05-23 13_40: EngineState:   disable_spi: 1 parameters
2018-05-23 13_40: EngineState:   enable: 1 parameters
2018-05-23 13_40: EngineState:   disable: 1 parameters
2018-05-23 13_40: EngineState:   set_toothed_wheel: 2 parameters
2018-05-23 13_40: EngineState:   set_flat_injector_lag: 1 parameters
2018-05-23 13_40: EngineState:   set_injector_lag: 2 parameters
2018-05-23 13_40: EngineState:   set_fan: 2 parameters
2018-05-23 13_40: EngineState:   set: 2 parameters
2018-05-23 13_40: EngineState:   get: 1 parameters
2018-05-23 13_40: EngineState:   showpin: 1 parameters
2018-05-23 13_40: EngineState:   set_injection_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_ignition_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_trigger_input_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_trigger_simulator_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_egt_cs_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_egt_spi: 1 parameters
2018-05-23 13_40: EngineState:   set_trigger_simulator_mode: 2 parameters
2018-05-23 13_40: EngineState:   set_fuel_pump_pin: 1 parameters
2018-05-23 13_40: EngineState:   set_ac_pin: 1 parameters
2018-05-23 13_40: EngineState:   set_alternator_pin: 1 parameters
2018-05-23 13_40: EngineState:   set_idle_pin: 1 parameters
2018-05-23 13_40: EngineState:   set_main_relay_pin: 1 parameters
2018-05-23 13_40: EngineState:   set_analog_input_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_logic_input_pin: 2 parameters
2018-05-23 13_40: EngineState:   set_pot_spi: 1 parameters
2018-05-23 13_40: EngineState:   tsinfo: 0 parameters
2018-05-23 13_40: EngineState:   reset_ts: 0 parameters
2018-05-23 13_40: EngineState:   set_ts_speed: 1 parameters
2018-05-23 13_40: EngineState:   binarytest: 0 parameters
2018-05-23 13_40: EngineState:   injector: 2 parameters
2018-05-23 13_40: EngineState:   fuelpumpbench: 0 parameters
2018-05-23 13_40: EngineState:   fuelpumpbench2: 1 parameters
2018-05-23 13_40: EngineState:   fanbench: 0 parameters
2018-05-23 13_40: EngineState:   fanbench2: 1 parameters
2018-05-23 13_40: EngineState:   dizzybench: 0 parameters
2018-05-23 13_40: EngineState:   milbench: 0 parameters
2018-05-23 13_40: EngineState:   fuelbench: 3 parameters
2018-05-23 13_40: EngineState:   sparkbench: 3 parameters
2018-05-23 13_40: EngineState:   fuelbench2: 5 parameters
2018-05-23 13_40: EngineState:   sparkbench2: 5 parameters
2018-05-23 13_40: EngineState: For more visit http://rusefi.com/wiki/index.php?title=Manual:Software:dev_console_commands
2018-05-23 13_40: EngineState: FATAL error: HW timer state 1
after reboot
2018-05-23 13_37: EngineState: FATAL error: HW timer state 1
2018-05-23 13_37: EngineState: confirmation_set date 1527082629:19
2018-05-23 13_37: CommandQueue: Took 3 attempts
2018-05-23 13_37: EngineState: confirmation_ls /:4
2018-05-23 13_37: EngineState: Error: No File system is mounted
2018-05-23 13_37: EngineState: confirmation_set date 1527082646:19
Skype : shiva-p
+66 8 5357 5159
Did you update your discovery programming chips interface? See below for some instructions on how to update the discovery firmware.
https://rusefi.com/wiki/index.php?title=Manual:Software:User/en#Load_firmware
Tambralinga
kb1gtt wrote:
Wed May 23, 2018 9:30 am
yes firmware new v2.J29.S0
Skype : shiva-p
+66 8 5357 5159
A smaller problem is unknown [set_engine_type 16]
there needs to be a space after "set" now
set engine_type 16
but the bigger problem is the thing you are reporting, let me try reproducing
Tambralinga
russian wrote:
Fri May 25, 2018 2:38 am
first step install firmware have error CRC.
EngineState: ERROR: CRC header size
I can not solve this proplem.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
The problem that from pb1 ่junp to ground.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
help me
The right values for first start engine.
what default standard for mitsubishi?
old config 2015
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:
Mon May 28, 2018 4:01 pm
help me
I do not understand the question. Do you want all 30 values for all these three screens? what seems to be problem exactly what is different with your other cars?
Tambralinga
I can start the engine with the value.
trigger type= miata NA
trigger angle offset =0
advance deg = 15
charge =70
it ok for mitsubishi
if connect afr LSU 4.2 need to use cj125 ?
Skype : shiva-p
+66 8 5357 5159
Tambralinga
I don't know how did it happen WARNING
2018-06-11 23_04: EngineState: WARNING: interpolate: Same x1 and x2 in interpolate: 0.00/0.00
2018-06-11 23_05: EngineState: WARNING: interpolate: Same x1 and x2 in interpolate: 0.00/0.00
Skype : shiva-p
+66 8 5357 5159
Just made a chance to make these warnings more detailed - please update to latest firmware and tell me the new message
https://github.com/rusefi/rusefi/commit/e3dfcc4df910e033788a3eb838db2b8754d737db
Tambralinga
russian wrote:
Tue Jun 12, 2018 9:46 am
new firmwaer ok no warning
Skype : shiva-p
+66 8 5357 5159
Tambralinga
Can be used normally, but there are problems warning TPS
2018-07-04 19_02: EngineState: WARNING: TPS too low: 0.03
2018-07-04 19_02: EngineState: WARNING: TPS too low: 0.15
2018-07-04 19_02: EngineState: WARNING: TPS too low: -0.03
tpsinfo
2018-07-04 19_03: EngineState: confirmation_tpsinfo:7
2018-07-04 19_03: EngineState: tps min (closed) 126/max (full) 761 v=0.73 @PC1
2018-07-04 19_03: EngineState: current 10bit=126 value=0.00 rate=0.00
Skype : shiva-p
+66 8 5357 5159
Analog Input Settings -> "TPS low value detection threshold" you probably want it at zero or -3 maybe?
Tambralinga
russian wrote:
Mon Jul 09, 2018 9:32 pm
What should be used?
Skype : shiva-p
+66 8 5357 5159
Latest project file now contains some explanation
tpsErrorDetectionTooLow = "TPS error detection, what TPS % value is unrealistically low"
tpsErrorDetectionTooHigh = "TPS error detection, what TPS % value is unrealistically high"
Default values are -5% for tpsErrorDetectionTooLow and 105% for tpsErrorDetectionTooHigh or something like that.
