line:194:time,877.413,rpm,1199,maf,0.98,MAP,168.01,map_r,167.59,baro,459.92,afr,10.97,vref,0.98,vbatt,2.62,TP,10.46,CLT,70.00,MAT,30.00,ckp_c,87587,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
line:3921:wave_chart,c2!d!0_7!inj2!d!757!inj3!u!1501!c2!u!1551_8!spa1!u!1569!spa1!d!1973!c2!d!2485_9!inj1!d!3262!c1!u!3320_0!c2!u!4007_1!inj4!u!4027!spa1!u!4071!spa1!d!4474!c2!d!4967_2!inj3!d!5751!r!1199!5754!c2!u!6481_3!inj2!u!6509!spa1!u!6578!spa1!d!6980!c2!d!7439_4!inj4!d!8281!c1!d!8315_5!inj1!u!9011!c2!u!9059_6!spa1!u!9079!spa1!d!9467!c2!d!10005_7!inj2!d!10761!inj3!u!11510!c2!u!11548_8!spa1!u!11569!spa1!d!11973!c2!d!12489_9!inj1!d!13265!c1!u!13317_0!c2!u!14010_1!inj4!u!14022!spa1!u!14070!spa1!d!14474!c2!d!14963_2!r!1200!15750!inj3!d!15763!c2!u!16482_3!inj2!u!16508!spa1!u!16577!spa1!d!16979!c2!d!17436_4!inj4!d!18275!c1!d!18312_5!inj1!u!19005!c2!u!19055_6!spa1!u!19073!spa1!d!19461!c2!d!20002_7!inj2!d!20760!inj3!u!21503!c2!u!21551_8!spa1!u!21569!spa1!d!21973!c2!d!22485_9!inj1!d!23259!c1!u!23320_0!c2!u!24007_1!inj4!u!24024!spa1!u!24069!spa1!d!24472!c2!d!24967_2!r!1199!25752!inj3!d!25757!c2!u!26479_3!inj2!u!26504!spa1!u!26574!spa1!d!26976!c2!d!27439_4!inj4!d!28278!c1!d!28315_5!inj1!u!29009!c2!u!29059_6!spa1!u!29077!spa1!d!29465!c2!d!30005_7!inj2!d!30757!inj3!u!31508!c2!u!31548_8!spa1!u!31567!spa1!d!31971!c2!d!32489_9!inj1!d!33263!c1!u!33317_0!c2!u!34010_1!inj4!u!34020!spa1!u!34070!spa1!d!34474!c2!d!34963_2!r!1200!35751!inj3!d!35762!c2!u!36482_3!inj2!u!36508!spa1!u!36577!spa1!d!36979!c2!d!37436_4!inj4!d!38274!c1!d!38319_5!inj1!u!39011!c2!u!39055_6!spa1!u!39079!spa1!d!39461!c2!d!40002_7!inj2!d!40760!inj3!u!41503!c2!u!41551_8!spa1!u!41569!spa1!d!41973!c2!d!42485_9!inj1!d!43265!c1!u!43321_0!c2!u!44007_1!inj4!u!44025!spa1!u!44069!spa1!d!44472!c2!d!44967_2!r!1199!45752!inj3!d!45757!c2!u!46479_3!inj2!u!46504!spa1!u!46574!spa1!d!46976!c2!d!47439_4!inj4!d!48279!c1!d!48316_5!inj1!u!49009!c2!u!49059_6!spa1!u!49077!spa1!d!49465!c2!d!50005_7!inj2!d!50757!inj3!u!51508!c2!u!51547_8!spa1!u!51566!spa1!d!51970!c2!d!52489_9!inj1!d!53263!c1!u!53317_0!c2!u!54010_1!inj4!u!54020!spa1!u!54074!spa1!d!54474!c2!d!54963_2!r!1200!55750!inj3!d!55761!c2!u!56482_3!inj2!u!56508!spa1!u!56577!spa1!d!56979!c2!d!57436_4!inj4!d!58274!c1!d!58312_5!inj1!u!59005!c2!u!59055_6!spa1!u!59073!spa1!d!59461!c2!d!60002_7!inj2!d!60760!inj3!u!61503!c2!u!61551_8!spa1!u!61569!spa1!d!61973!c2!d!62485_9!inj1!d!63259!c1!u!63320_0!c2!u!64007_1!inj4!u!64025!spa1!u!64069!spa1!d!64472!c2!d!64967_2!r!1199!65752!inj3!d!65757!c2!u!66479_3!inj2!u!66505!spa1!u!66574!spa1!d!66976!c2!d!67439_4!inj4!d!68278!c1!d!68315_5!inj1!u!69009!c2!u!69059_6!spa1!u!69077!spa1!d!69466!c2!d!70005_7!inj2!d!70757!inj3!u!71508!c2!u!71547_8!spa1!u!71566!spa1!d!71970!c2!d!72489_9!inj1!d!73263!c1!u!73317_0!c2!u!74010_1!inj4!u!74020!spa1!u!74074!spa1!d!74474!c2!d!74963_2!r!1200!75750!inj3!d!75762!c2!u!76482_3!inj2!u!76508!spa1!u!76577!spa1!d!76979!c2!d!77436_4!inj4!d!78274!c1!d!78319_5!inj1!u!79012!c2!u!79055_6!spa1!u!79079!spa1!d!79461!c2!d!80002_7!inj2!d!80760!inj3!u!81503!c2!u!81551_8!spa1!u!81569!spa1!d!81973!c2!d!82485_9!inj1!d!83266!c1!u!83320_0!c2!u!84007_1!inj4!u!84025!spa1!u!84069!spa1!d!84471!c2!d!84967_2!r!1199!85752!inj3!d!85757!c2!u!86479_3!inj2!u!86504!spa1!u!86574!spa1!d!86976!c2!d!87439_4!inj4!d!88279!c1!d!88315_5!inj1!u!89009!c2!u!89059_6!spa1!u!89077!spa1!d!89465!c2!d!90005_7!inj2!d!90757!inj3!u!91508!c2!u!91547_8!spa1!u!91566!spa1!d!91970!c2!d!92489_9!inj1!d!93263!c1!u!93317_0!c2!u!94010_1!inj4!u!94020!spa1!u!94070!spa1!d!94474!c2!d!94963_2!r!1200!95751!inj3!d!95762!c2!u!96482_3!inj2!u!96508!spa1!u!96577!spa1!d!96979!c2!d!97435_4!inj4!d!98274!c1!d!98312_5!inj1!u!99005!c2!u!99055_6!spa1!u!99073!spa1!d!99461!c2!d!100002_7!inj2!d!100760!inj3!u!101503!c2!u!101551_8!spa1!u!101570!spa1!d!101974!c2!d!102485_9!inj1!d!103259!c1!u!103320_0!c2!u!104007_1!inj4!u!104025!spa1!u!104069!spa1!d!104471!c2!d!104967_2!input1 A8!d!105565!r!1199!105752!inj3!d!105757!input1 A8!u!105965!c2!u!106479_3!inj2!u!106505!spa1!u!106574!spa1!d!106977!c2!d!107439_4!inj4!d!108279!c1!d!108315_5!inj1!u!109009!c2!u!109059_6!spa1!u!109077!spa1!d!109466!c2!d!110005_7!,
line:194:time,877.971,rpm,1199,maf,0.99,MAP,167.97,map_r,168.54,baro,461.68,afr,10.98,vref,0.99,vbatt,2.64,TP,10.61,CLT,70.00,MAT,30.00,ckp_c,87643,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
line:218:analog_chart,0.00000|0.00000|49.42996|2001.00000|118.45639|3002.00000|227.24404|2003.00000|296.32083|3004.00000|359.36901|1005.00000|412.85644|2006.00000|480.91885|3007.00000|591.88629|2008.00000|659.61059|3009.00000|,
line:194:time,878.205,rpm,1199,maf,0.99,MAP,167.95,map_r,168.48,baro,463.15,afr,10.98,vref,0.99,vbatt,2.64,TP,10.61,CLT,70.00,MAT,30.00,ckp_c,87667,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
line:194:time,878.424,rpm,1199,maf,0.97,MAP,167.90,map_r,168.70,baro,462.85,afr,10.95,vref,0.97,vbatt,2.61,TP,10.30,CLT,70.00,MAT,30.00,ckp_c,87688,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
line:194:time,878.640,rpm,1200,maf,0.98,MAP,167.94,map_r,168.26,baro,461.68,afr,10.97,vref,0.98,vbatt,2.63,TP,10.46,CLT,70.00,MAT,30.00,ckp_c,87710,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
line:194:time,878.856,rpm,1200,maf,0.98,MAP,167.92,map_r,168.15,baro,461.39,afr,10.97,vref,0.98,vbatt,2.63,TP,10.46,CLT,70.00,MAT,30.00,ckp_c,87732,fuel_base,17.01,fuel_lag,25.50,fuel,42.51,timing,87.34,
