[help needed] help me what happen in my TunnerStudio
ruben
I have a problem with Tunner studio. printscreen below that of the Tunner studio. what does it mean?
then on my development board LED that blink blue and yellow. what does it mean? I've followed the steps on the forum but the color blue LED does not blink. Thanks
Re: help me what happen in my TunnerStudio
Hello
Re: the blinking - expected behavior is explained on our laconic User Manual @ http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#LEDs
The Tuner Studio dialog is totally fine sometimes, but in your case I am concerned about the 'NOT COMPATIBLE' label in the corner. Are you using the latest firmware with latest rusefi.ini file?
ruben
russian wrote:Hello
iI've been using the latest filmware but the same does not work. I download Tunner v2.6.14 existing studio.
I see on the web rusefi.com used Tunner studio using v2.6.01 version but I did not find a link to download. do you have a link tunnerstudio v2.6.01?
and I've downloaded filmware snapshot_20150215_2337_rusefi if it is not used. should show me the link to download the latest firmware? thanks
ruben
how to connect to potensio with tunnerstudio
how to ensure that the program can run rusefi? I have an example of how to connect the case of TPS with tunnerstudio? thanks
Re: how to connect to potensio with tunnerstudio
I am really not sure what you are sayingruben wrote:how to ensure that the program can run rusefi? I have an example of how to connect the case of potensio with tunnerstudio? Potensio here I gunakkan as TPS. thanks
What hardware do you have? What are you trying to do right now? You need to provide more context.
ruben
Can you show how to connect tunnerstudio with TPS? only TPSrussian wrote:I am really not sure what you are sayingruben wrote:how to ensure that the program can run rusefi? I have an example of how to connect the case of potensio with tunnerstudio? Potensio here I gunakkan as TPS. thanksI understand it's something about throttle position sensor which is a potentiometer?
I want to know when connecting TPS with tunnerstudio, displays on show work? thanks
A good answer starts with a good question. It is hard to provide you with a good answer without understanding what you have and where you are. You are ignoring my questions and this does not help me in helping you.
If you prefer you can post some pictures in response.russian wrote:What hardware do you have? What are you trying to do right now? You need to provide more context.
klyttle
Not wanting to put words in anyone's mouth, but what I think the gentleman is trying to ask is how to display TPS data using TunerStudio.
I hope I got the gist of his query correctly.
klyttle
Right, that's something about TPS and TunerStudio, but details matter
Does original poster have just an stm32f4discovery? or maybe he has one of our boards? or maybe he has designed his own board? What does OP use for voltage dividing? Does the OP realize that you cannot just feed 5v into stm32f4 analog input pin? Some of these answers would help to clarify where OP stand.
ruben
russian wrote:Right, that's something about TPS and TunerStudio, but details matter
development board stm32f4 and potentiometer (variable resistor). I want to ask how to simulate in tunnerstudio with two existing hardware?
It looks like that 2 wire POT is not connected to the discovery, I would first suggest connecting it to the discovery, then I would suggest using a 3 wire as shown in the schematic. See page 3 found here http://sourceforge.net/p/rusefi/code/HEAD/tree/trunk/hardware/frankenso/frankenso_schematic.pdf?format=raw Note your 3rd wire will need to be connected to 3.3V (not 5V as done on the frankenso board), POT wiper to PC1 and 1st POT wire to gnd.
1) erase chip content with ST LInk Utility
2) download fresh bundle http://rusefi.com/build_server/rusefi_bundle.zip
3) program current firmware version
4) open TS, create new project with current rusefi.ini
Make sure you have the green OK in the left corner. Open "Board Inputs" and you will see that TPS is set to PA2:
5) connect pot to GND, 3v and PA2 for signal
6) in TS, right-click to select TPS gauge
ruben
Now I see another problem: you are connecting to microUSB but there is not jumper. You need to put a jumper on GND and PB1 pins
See also http://rusefi.com/wiki/index.php?title=Manual:Software:TunerStudio_connectivity
See also http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#Communication_mode
ruben
russian wrote:Now I see another problem: you are connecting to microUSB but there is not jumper. You need to put a jumper on GND and PB1 pins
I've been following your way, but I have not been able to connect to it, but here I want to ask how I know that the software rusefi and TS has been connected with the development board?
whether this picture shows only connected to the simulator rusefi or has been connected to the development board?
that TS picture should be same for simulator and real hardware
Can you please install skype and http://www.teamviewer.com/ ? I can log into your PC and see if I would see anything strange.
Do you see a STMicroelectronics port in your device manager?
ruben
yes, port microcontroller already exists in the device manager. is there something wrong?
Well, you have the serial driver installed and this looks fine. If you have the jumper between GND and PB1 pins then this should work.
If it does not, please contact me via Skype or private message when you have time to troubleshoot this via teamviewer remote desktop terminal.
