Same engine and yes, they are both sister models. OBD1 Honda configuration. Andrey told me to make a thread (: he's being awesome and setting my jump wires up
Has same three VR position sensors as the Accord. I am going to use CKP and CYP and drop TDC since Frankenso only has two channels - this case it will be true sequential injection but with a little longer time to start.
Re: 1993 honda prelude bb2 with f22a1
Posted: Wed Jun 24, 2015 1:08 am
Joe, can you check voltage on B10 - vehicle speed sensor wire? I guess it's not 12v signal, but I would feel better knowing for sure.
Posted: Wed Jun 24, 2015 1:17 am
by 3gAccord
I will do so tomorrow. Let me see if I can reference it in these shop manuals tho. Bak shortly
Posted: Wed Jun 24, 2015 1:24 am
by 3gAccord
Per manual h22 engines (JDM) are 0-12V, my engine and most prelude and accord are f22 or h23 engines so they are 0-5V
Posted: Wed Jun 24, 2015 1:31 am
by 3gAccord
I know that the f22a1 im using doesn't have vtec but I think yours did. Eventually I'm swapping heads to an h22 head which does have vtec. Whats the state of vtec in rus so far?? It's just a solenoid toggled by ECU to divert oil flow
Posted: Wed Jun 24, 2015 2:05 am
I think I am done with soldering, I just need a couple days to test it more & document which wire is what.
Very excited! I should have the engine in shortly, if not we'll fired it up on the stand
Posted: Sat Jun 27, 2015 12:41 pm
Shipping in an hour.
Posted: Thu Oct 01, 2015 8:14 am
by 3gAccord
Finally getting around to getting the prelude up on the Frankenso 0.4 board. Should have it up and running in the next week or two. Is tunerstudio autotune compatible with RusEFI?
Posted: Thu Oct 01, 2015 10:14 am
3gAccord wrote:Is tunerstudio autotune compatible with RusEFI?
yes, see
glad you are making progress!!!
Posted: Thu Oct 01, 2015 11:01 pm
by 3gAccord
Awesome. I've got a friend who wants to get a setup for his car, same car but h22 JDM engine. OBD1 once we get mine . I'm having some troubles communicating with my setup on my linux laptop (No USB devices show up) but it works on the windows one, so... Going to be finishing up some odds and ends this coming week then should be ready to start up!
Posted: Fri Oct 02, 2015 1:21 am
by 3gAccord
russian: Do you remember the settings (engine type etc) that this one has? A few friends are really interested in this thing! More than I expected. Thanks for the help so far!
Posted: Fri Oct 02, 2015 3:02 pm
3gAccord wrote:russian: Do you remember the settings (engine type etc) that this one has? A few friends are really interested in this thing! More than I expected. Thanks for the help so far!
