[rusEfi] frankenstein 0.11 on nissan sr20ve neo vvl #34
matt
Post by matt »
consider this is 2nd project, my chasis is kia carens 1.8 swap with nissan engine.
at first it was with cvt transmission, but it cause many problem with standart ecu.
neo vvl not working if not install with full engine and dashboard wiring harness.
i change to manual transmission and ecu was swap with ms2 with 4g63 cam angle sensor.
for now i prefer it running with standard 360 slot cam angle sensor.
i can provide trigger pattern in this weekend.
Re: frankenstein 0.11 on nissan sr20ve neo vvl
matt wrote:with 4g63 cam angle sensor.
Do you have pictures of both sensors, complete units? If these are interchangeable I wonder if one can use Nissan sensor on a Miata?
matt
Post by matt »
Left is 4g63 (vr4), right is nissan 360 slot. Still need to modified the plate, if not it not touch the camshaft.
matt
Post by matt »
here is 360 slot look like.
I guess let's begin without the 360 channel, I believe sync works based of the 4 slot?
matt
Post by matt »
sorry, i don't know any about trigger calculation.
so i need to log with only 4 slot?
i can provide this 4 slot in evening or tomorrow.
matt wrote: so i need to log with only 4 slot?
Yes, please log only 4 slots as first step. Please select 'custom skipped wheel" total=4 skipped=0 while doing that.
What year/donor is your sr20ve? Want to name this trigger properly.
matt
Post by matt »
4 slot
matt
Post by matt »
i'am also logging for a 360 slot. in case if you need that.
custom tooth wheel is set to 36.
matt
Post by matt »
not sure, but i believe it come from primera p11 year 1995-2002.
matt wrote:4 slot
20170318 should now sync on Nissan Primara trigger.
We will deal with the 360 slot 2nd channel a bit later, you can start your car with 4 slots.
will this 360-slot thing allow to track efficiency of each cylinder and measure instantaneous acceleration? just wondering how the whole thing looks like - the trigger and the sensor... at 6000 rpm it means a pulse each 2.7~µs - probably, not an easy task for a microcontroller?
puff wrote:at 6000 rpm it means a pulse each 2.7~µs - probably, not an easy task for a microcontroller?
360 on cam is only 3 times more work compared with a 60/2 on crank. We will see :)
matt
Post by matt »
in TS it should be nissan trigger or custom tooth wheel? i test both is sync. i'am gonna to re-wired my cas now. hopefully it will start tonight.
Nissan trigger, make sure you are using latest firmware.
matt
Post by matt »
yes. iam using snapshot_20170318_2151_rusefi
matt
Post by matt »
and YESSS!! its start..
matt
Post by matt »
and it start only once, not for 2nd time.. i try with custom tooth wheel rpm show correct, but with nissan looks like not stable and sometime remain 0 rpm. gonna work on it tomorrow.
Do not even try 4/0 custom wheel - it would not work right for sure.
Do you have any console log files? There could be useful info there.
Next time try enable trigger_details & writeconfig commands in console or "print sync details to console" option in TS. This would produce some helpful messages with synchronization progress details.
matt
Post by matt »
just curious, is this trigger event?
matt wrote:out of curiosity, is this trigger event?
this whole line is what you see in engine sniffer in console, raw data for it.
matt
Post by matt »
i'am not so understand on issue #314 'faster cranking with battery-backed RAM'.
meaning on my stm32 disc got battery or i must put a battery at the back of my frankenso rev0.2?
matt wrote:i'am not so understand on issue #314 'faster cranking with battery-backed RAM'.
https://github.com/rusefi/rusefi/issues/314 is an improvement idea which was not implemented yet. some battery for stm32 does not matter where it would be - but that's just an idea at this point.
matt
Post by matt »
today progress.
with nissan trigger setup in TS, no rpm sync.
with custom tooth setup it start for a 5 second, and engine stop if throtle if press.
i can start engine with standard ecu and log a trigger in console if its needed.
matt
Post by matt »
russian wrote:Next time try enable trigger_details & writeconfig commands in console or "print sync details to console" option in TS. This would produce some helpful messages with synchronization progress details.
can i do this while cranking?
matt
Post by matt »
4 slot with enable trigger_details & writeconfig commands.
matt
Post by matt »
i'am also logging for 360 slot if this is needed.
I've widened the expected cap a little bit. It was from 8.70 to 14.50 and it is supposed to sync on 9.69, 9.62 etc.
We do not need 360 slot data so far. I wonder if it starts on 4/0 because your trigger offset is 180, 360 or 540 off? Did you get a timing gun?
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=38.76/0.02/9.61 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.02/38.76/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=38.74/0.02/38.76 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=1
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.02/38.74/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=37.72/0.02/38.74 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 403: gap=0.09/37.72/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=9.69/0.09/37.72 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/9.69/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.73/0.02/9.69 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.73/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.60/0.02/38.73 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:48 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.60/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=37.89/0.02/38.60 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.09/37.89/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=9.62/0.09/37.89 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/9.62/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=38.86/0.02/9.62 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 404: gap=0.02/38.86/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.84/0.02/38.86 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.84/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=37.81/0.02/38.84 @ 5 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.09/37.81/0.02 @ 6 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=9.60/0.09/37.81 @ 7 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/9.60/0.09 @ 0 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.75/0.02/9.60 @ 1 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.75/0.02 @ 2 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=38.88/0.02/38.75 @ 3 while expected 8.70/14.50 and NaN/100000.00 error=0
Tue Mar 21 18:17:49 SGT 2017<EOT>: postMessage EngineState: 405: gap=0.02/38.88/0.02 @ 4 while expected 8.70/14.50 and NaN/100000.00 error=0
matt
Post by matt »
it start with 4/0 at 0 degree offset, but just a few second and engine not stable.
with nissan trigger no rpm sync at all.
p/s: no timing gun yet
