Can someone help with trigger configuration for a Nissan ( engine KA24DE) which has a 180 degree reference signal and a 360 pulse signal from the camshaft( 360 pulses or I could use 720 pulses for 2 rotations)?
Re: Nissan engine KA24DE
Posted: Tue May 09, 2017 1:10 am
by stefanst
I thought that was an old-school distributor engine. Any pictures of the trigger wheels?
Posted: Wed May 10, 2017 2:21 pm
by filip5
Hi ,
Attached is the original Nissan distributor that has 180degree ref and 1 degree pulse out of 360 degree rotation. The megasquirt recommends replacing it with these 2 discs. One has a hole in it.
Posted: Wed May 10, 2017 3:43 pm
Please do not double-post same information on two different threads, I believe this is creating some confusion.
On the pictures above I see two different wheels. I believe the wheels above with one large one and without 360 are after-market wheels. I believe the wheel below with 360 is the original wheel, and the second channel is NOT single tooth there but four tooth with one slot bitter than others.
We need to focus on ONE correct wheel for you specific engine. Have you tried existing nissan trigger signal?
Attached is the engine sniffer for nissan altima 94 with existing cam/crank sensor as it was posted here previously. Can anybody tell if the ignition outputs for cylinder 1(PC9),2(PC7),3(PE14),and 4(PE12) together with injectors 1(pin is NONE for now it is supposed to be on PE6 but it is giving me a conflict with another output GPIO_1 so I removed it for now) ,2(PE4),3(PD3) and 4 (PC13) are firing correctly?
Posted: Fri May 12, 2017 3:32 pm
Is this on real car which real starter? Were injectors/coils connected? Plugs in?
It looks close but not sure if it's perfect. Green line is your top dead center #1 line - it should be consistently positioned with the signals and will coil. One of them looked great with coil #1 just before the green line like you would expect.
Posted: Fri May 12, 2017 5:16 pm
by filip5
I do not see ign coil #2 that is PC7 and if PE12
as firing. I did not see led firing as well.
Does the graph display anything wrong about them?
The injector coils seem to fire correctly.
Posted: Fri May 12, 2017 6:36 pm
Coil#2 is there but it's not mapped as default pinout document says (it says PE14 next to COIL#2 on the left of the picture) - that's my fault, I've temporary set my engine as default engine in preparation for this race.
If you do set engine_type 0
in console you would get true default pin-out.
Same would explain GPIO_1 conflict. Actually I've just changed the name from too generit GPIO to FSIO_OUT. Sorry for the confusion, defaults would be set back properly on Monday and set engine_type 0 would not be required.
Posted: Sat May 13, 2017 6:35 pm
by filip5
It looks like there are some outputs and inputs that are used but not displayed what they are used for. I guess it would be helpful if all inputs/outputs are displayed and if there is any that should not be touched or modified it should be greyed out. Just a thought that in my case would be very helpful. By the way I got Nissan all figured out I think. Thanks for the help.
Posted: Mon May 15, 2017 8:52 am
filip5 wrote:It looks like there are some outputs and inputs that are used but not displayed what they are used for. I guess it would be helpful if all inputs/outputs are displayed and if there is any that should not be touched or modified it should be greyed out.
Can you please provide an example?
Posted: Tue May 16, 2017 3:26 pm
by filip5
I think you it was done already. Rusefi is displaying now all outputs and inputs and what they are used for.
Posted: Sun May 21, 2017 1:06 pm
by filip5
Can someone check why the second ignition coil on this picture shows a smaller dwell time than the first ignition coil, while ignition coil 3 and coil 4 have almost the same amount of dwell time.
This seems to happen when dwell is set at somewhere between 3.5ms and 4ms( see attached test1). If I set dwell at 2ms it seems to assign the same dwell time on 4 ignition coils(see attached test2).
Posted: Sun May 21, 2017 1:46 pm
Very limited telepathic abilities. Is this some sort of simulation or real engine? What is the RPM? Please post CurrentTune.msq from TunerStudio.
Posted: Sun May 21, 2017 8:58 pm
by filip5
Yes,
Attached.
Posted: Sun May 21, 2017 9:43 pm
russian wrote:Very limited telepathic abilities. (1) Is this some sort of simulation or real engine? (2) What is the RPM?
filip5 wrote:Yes
Can you please help me help you? Please provide a defailed response to both questions.
With very limited information you are sharing I would guess you are using some sort of external simulated signal? I would also suspect that the shape of the signal you provide does not match the shape of signal the firmware is expecting.
Posted: Sun May 21, 2017 9:44 pm
by filip5
The RPMs are written in the file names. This is an engine that is running.
Posted: Sun May 21, 2017 9:47 pm
by filip5
Dwell is written too in the file names. As you can see from the files when dwell is set at 2ms, it is almost the same for all 4 coils. When dwell is set at 3.5 ms than the coils 3 and 4 are close but coil 1 and 2 vary.
Posted: Sun May 21, 2017 9:48 pm
by filip5
The file that you submitted looks good but if you tried 4ms dwell you will see what I am discussing, or to be exact try dwell 3.5ms which I am using.
Posted: Sun May 21, 2017 9:54 pm
I believe this is about expected and actual shape mismatch. I hope to have a tool to help us troubleshoot this in about 20 minutes.
Posted: Sun May 21, 2017 9:57 pm
by filip5
Ok, thanks. I am concerned that operating this way one coil will saturate and get hot and the other will under perform if what I am seeing in engine sniffing is true.
Posted: Sun May 21, 2017 10:14 pm
Are you running your engine on rusEfi or are you just sniffing signals? If you are running an engine I would love to see a video of your setup!
New tool ready, would take about 45 minutes for new bundle to include new version of console.
step 1) set 'sensor sniffer' to 'trigger' mode
step 2) look at new tool and compare how far are your angles from angles firmware reports with self-stimlation since these are the expected angles at the moment. There is a good chance that the angles recorded previously were not great and we would be able to correct them a bit which would make your coil control more precise.
Posted: Sun May 21, 2017 10:22 pm
by filip5
When I am done I will ask you to come and see it, right now I am just fine tuning and calibrating items.
Posted: Sun May 21, 2017 10:52 pm
Is this a rusEFI only engine? Or is this 50% OEM and 50% rusEFI? There are many things you know that we do not. A quick picture or quick video is a great help. Or at minimum a brief write up about what is going on is very helpful to those of us that have not physically seen the setup. Also please keep in mind that what may appear to be 1 issue to you, often appears as 40 potential issues to the developers. The more information you provide, the faster developers can eliminate the 39 other possible issues.
Is rusEFI the only source for ignition, or is the ignition potentially driven by an external device like and OEM ECU?
Posted: Mon May 22, 2017 12:30 am
by filip5
Ok. I think it is probably the Nissan camshaft sensor that is causing it. I just saw your picture posted with 4ms dwell time and it seems decent and the same for all coils.
Thank you.
Posted: Mon May 22, 2017 7:17 pm
by filip5
I just noticed something that might be of interest. I see the problem happening with ignition coils 1 and 2 dwell time as soon as I pass 2,600 rpm it looks like. At 2,590 rpm the problem does not show up
and coils have the same dwell time that is about 3.50ms.
I noticed that your default sniffer for engine and sensor is set at about that value for max sniffing. Do you think might be a issue there? I see that you do not have that problem at 4,300rpm that you posted though.
Attached are some pictures with rpm data in their file names. For some reason the sensor sniffing files came dark but you still can see the graph.
Posted: Mon May 22, 2017 7:25 pm
kb1gtt wrote:Is this a rusEFI only engine? Or is this 50% OEM and 50% rusEFI? There are many things you know that we do not. A quick picture or quick video is a great help. Or at minimum a brief write up about what is going on is very helpful to those of us that have not physically seen the setup. Also please keep in mind that what may appear to be 1 issue to you, often appears as 40 potential issues to the developers. The more information you provide, the faster developers can eliminate the 39 other possible issues.
I was recently suprised by how much fuel is needed to start my green race car nicer - cranking base fuel of 9ms, which is then multiplied by 1.5 "cranking duration correction". I am still not happy with the way my green car starts, and that's strange since red car seems to start better.
Re: Nissan engine KA24DE #36
Posted: Tue May 23, 2017 12:53 am
Another thing - can you please post a screen shot of your Trigger Shape pane similar to screenshot_new_tool.png above? I suspect that rusEfi angle information for your nissan 4+1 trigger is not precise enought, I thikn that you can produce more accurate values using this tool and I would be able to improve the data in the firmware which would improve precision of your dwell duration.
Posted: Sat May 27, 2017 8:48 pm
by filip5
Hi guys,
Here I have an issue with the VE table. Does not seem to work properly.
Let say that I have set the VE table at 3.56ms injection table for the entire table. Now if I keep the MAP set at 10% than as I increase the RPM by opening throttle the injection time
remains consonant at 3.56ms more or less which is good because it supposed to stay contstant. Remember the VE table is constant. MAP sensor let say is disconnected.
When I increase the MAP pressure by connecting the sensor and opening throttle the injection time increases even though the VE table says it should stay the same.
Is that anything else effecting the injection time beside VE table? Attached are the log files and tuning file.
Thanks
Posted: Sat May 27, 2017 9:09 pm
filip5 wrote:Let say that I have set the VE table at 3.56ms injection table for the entire table. Now if I keep the MAP set at 10% than as I increase the RPM by opening throttle the injection time
remains consonant st 3.56ms more or less which is good. Remember the VE table is constant. MAP sensor let say is disconnected.
VE table axises are RPM and MAP measured in kPa. Just fixed a typo where VE asix was labeled "MAPValue %" this was a typo, should read "MAP kPa". Will look at the logs in a bit!
