Proton satria with 4g13/4g15 engine.
I got new chassis, name as proton satria, similar with Mitsubishi colt mirage. Currently running with carburetor and I will fit complete set of injection system by this week. I disassemble distributors and found it using 4 slot crank and 1 slot cam, and maybe it similar with Mazda 4/1 trigger?
I will let it running with standard ecu, once I change bottom block with 4g15 rusefi will take a place.
Re: Proton satria with 4g13/4g15 engine.
Cool keep us posted.
nice workmatt wrote:Hi all...
Sent from my SM-J510GN using Tapatalk
Quite busy this few month. Progress is going slow. This week I focus on engine built. It was 4g15 fit with 4g18 piston and crankshaft. So it will be nearly 1600 Cc instead of 1500cc. Locally we call it low cost stroker kit .
One more things, I'm going to assemble frankenso plug and play with standard MMC wire harness. Not sure what map sensor is using. Probably denso.Re: Proton satria with 4g13/4g15 engine.
i wonder my trigger is same as mazda 4+1 dohc.
@ can you verify this? I want to know is my trigger match with Mazda 4+1 trigger.
I am sorry I am very behind on my forum messages Maybe tomorrow but not sure. A lot of work
Seems my oem ecu can't handle my 294/294 camshaft, I plan to put Rusefi in place. Tomorrow (2.3.2018) I got race with this car. I not decide yet whether to participate or not. Maybe next month If my engine running fine.
