FSM Syrena 105L S-31 two stroke engine EFI conversion #41
Posted: Mon Jan 22, 2018 6:48 pm
by sir
Hello from Poland!
I would like to present my EFI retrofit project based on rusEFI.
Engine: S-31 type (used in FSO/FSM Syrena model 104, 105, 105L, R20 and BOSTO) -- pretty similar to Wartburg 353 engine
Type: Water-cooled, three-cylinder 2-stroke, piston-controlled intake
Mixture control: float-type carburetor
Fuel: premix 1:30
Capacity: 842 ccm
Rated output: 40 PS at 4300 rpm
Max. torque: 80 Nn at 2750 rpm
Parts used:
- fuel pump: universal 12V 4bar
- fuel filter: with integrated 3bar pressure regulator
- crank sensor: 5WK9 607 (opel astra, vectra)
- CLT sensor: NTC 10k M8 termistor
- IAT sensor: NTC 10k termistor
- MAP sensor: 16212460 (np. Opel Corsa)
- full Triumph 955i ITB body with fuel rail, injectors, IAC stepper motor and TPS
- some laser-cut parts designed by my
- STM32F4 Discovery kit mounted on prorotype board (only ADC input buffer, stepper driver -- mostly based on Frankenso circuit and 6x irgb14c40l IGTB transistors for injectors/coils driver)
Images can be enlarged by opening in new browser tab
My FSM Syrena 105L, 1976 - this car is not well known in the world, mainly its distribution took place in Poland during PRL times
engine bay - currently I have test engine installed in self-made test bench, see next photos
intake manifold adapter - plywood prototype and final metal one
crank sensor adapter
36/1 trigger wheel
Test bench
Engine just before first tests
First successful start attempts videos (as it turned out later with a damaged MAP sensor):
Latest test (with working MAP sensor):
Map sensor is connected only to middle cylinder throttle and has optimized measuring window (between inlet window opening start and wide open) set in rusefi firmware. As you can see in the film, the vacuum pressure varies only between 73 and 100 kPa (general 'problem' of 2 stroke engines). This can be a problem because I want to try with Speed Density first -- this can be difficult to tune well. In case of failure I will try alpha-N. I must also deal with interferences from ignition circuit (mostly from high voltage part) because sometimes there are false signals collected from crank sensor input. I think Coil-On-Plug coils type can help with that. At the moment engine starts, works witch SD but requires further tuning.
Re: FSM Syrena 105L S-31 two stroke engine EFI conversion #41
Posted: Mon Jan 22, 2018 6:59 pm
Welcome to the forum and welcome to the elite "running engine in first post" group!
Ps: can you please attach your currenttune.msq file? I want to build a collection of those.
Posted: Mon Jan 22, 2018 10:07 pm
by Abricos
WoW wonderful description ...
for 4 weeks several thousand video views ...
it's such a popular Engine ???
Posted: Mon Jan 22, 2018 10:23 pm
I am a google ninja! http://www.syrena.nekla.pl/forum/viewtopic.php?t=23771
Posted: Mon Jan 22, 2018 10:40 pm
by sir
Thx, good that finally we managed to activate my account and I could send my first post ;)
russian wrote:
Mon Jan 22, 2018 8:18 pm
Sure, but I have to admit, that for now VE map is in pretty bad shape. Map was, let's say 'tuned by ear' ;) I plan to buy a wideband, but I'm not sure how long will it operate well due the unburned oil in exhaust gases. Any hints on this topic will be appreciated.
Ignition map is flat -- 22,5 deg BTDC. Oryginally this engine has no distributor, but one contact breaker, one capacitor and one ignition coil for each cylinder. Additionaly no ignition advance mechanism. 22,50 deg BTDC is the factory preset for best operation at max. torque rpm (2750). It is known that this can't work optimally for the remaining engine speed range, so some time ago I constructed a contact-less ignition module controlled by lpc1114 with programmed ignition advance based on rpm:
and I have some ignition maps to start with, but at first I want to tune VE map well with stock configuration to avoid impact of any unclear factors.
someone has put a link to my post on Syrena forum at the Polish equivalent of reddit - that's why videos have so many views.
exactly this link ;)
Posted: Mon Jan 22, 2018 11:10 pm
by puff
This lpc1114-based ignition - what was the signal source? was it the 36-1 wheel?
Posted: Mon Jan 22, 2018 11:33 pm
by sir
Three unipolar TLE4905 hall sensors (one for each cylinder) triggered by neodymium magnet in aluminium bracket mounted at original cam. Mainly because then I wanted to fit whole pcb inside housing of the oryginal ignition without visible additional elements outside.
Posted: Tue Jan 23, 2018 1:59 am
Yes, well done, and congrats on being part of that elite group. Welcome to the forum.
This is a link you might have interest in.
viewtopic.php?f=4&t=286
Also have you found the wiki? If not you might find this link of interest.
https://rusefi.com/wiki/index.php?title ... schematics
Posted: Tue Jan 23, 2018 3:42 am
Can I please use this image for marketing purposes? It's just so.. beautiful!
Posted: Tue Jan 23, 2018 8:02 am
by sir
Oh, yes please. I know it looks funny, but it was the fastest way to build a prototype. It took me only a few hours to build it. I wanted to start testing as soon as possible :lol: I plan to do my own PCB with small dimensions, but maybe at a later stage.
Posted: Tue Jan 23, 2018 8:07 am
by sir
Thx, I have a good experience with irgb14c40l from my other ignition projects. But I will look at this link too.
Yes, I know this wiki, I started playing with EFI from that, long time before I created an account on the forum.
Posted: Tue Jan 23, 2018 10:59 am
I don't know, I think he's got to many components :)
I like the simplicity. I also paused on that picture and looked at it for a while. Just like art, I looked at it upside down, and tried to let it speak to me. When I see that picture it says "Hey, I've got stuff to do, so lets get it done."
If you do something, I could offer some help. It looks like your setup is very simple, so it probably would not take to long. Do you think you might put it inside a distributor cap or something like that? If you design your own, if you post it somewhere I can review it and offer feedback. Or if you get me some of the details of how you want to mount it and such, I could likely draft something for you. Either that, or of course a Frankenso could do most of what you're doing, but with external igniters. If you don't ignore the cost of your labor, the Frankenso would likely be the lowest cost solution. Have you seen Prometheus? We have heard good things from a couple of people who have done that board layout. See the below link.
viewtopic.php?f=4&t=1215
Also I wonder how @ would feel about adding multiple map support. If you could get one MAP per cyl, for individual cyl control, would that be of interest? In the past I've made a board I called MultiMap, it combined multiple map sensors into one, reporting the lowest signal. I understand that the ITB folks commonly use a network of small hoses and small check valves to combine the signals. This did that same thing but electronically. Bu using the lowest MAP signal, the other cyl's tend to run a pinch rich, which is OK from a performance standpoint.
https://github.com/jharvey/MultiMAP
About WO2, I would suggest Exhaust Gas Temperature (EGT) sensors. Thermocouples in the exhaust are commonly used to indicate if you have an engine problem. WO2's are typically for emissions purposes. The entire WO2 tuning is kind of blah. If power is your concern, typically you would tune such that you are rich, then back it down little by little until you see peak power. then you use EGT's looking for abnormal temperatures which would indicate engine problems. The O2 feedback is really only helpful when you don't know if your fuel pump is delivering enough fuel. AKA you could command extra fuel, but it might not get delivered if your fuel rail pressure is dropping. The other place that the O2 feedback is handy is for the auto-tuning. It's kind of nice to let the computer get you close to peak HP with out the human having to type numbers into the table.
Posted: Tue Jan 23, 2018 11:36 pm
by sir
Putting all into original ignition breakers cover might be difficult...
This is my previous ignition system conversion:
original ignition module with contact breakers plate looks like this:
my lpc1114-based board with variable ignition timing:
As you can see in the photos above, the stm discovery board will definitely not fit. Even without discovery board, placing the controller itself with all necessary peripherals on such a small PCB will be rather impossible. Until now, I wanted it to look like the original, but after conversion from the carburetor to the ITB EFI, it will be hardly possible to hide such a modification... so I do not need to fit everything in the original ignition housing, right? :)
This can be very helpful, thx -- I'll keep that in mind.
I want to simplify the PCB and design in such a way that it would have only what I really need. That's why I do not want use Frankenso. I've seen Prometheus -- yes, it's smaller, but I think I still want to do my own :)
About that... Currently I use modificated rusefi firmware to sample MAP sensor only once per rev (because i have MAP sensor connected to only one cylinder -- no common collector with the other 2 cylinders):
diff --git a/firmware/controllers/map_averaging.cpp b/firmware/controllers/map_averaging.cpp
index 06495ab5..ff293d3c 100644
--- a/firmware/controllers/map_averaging.cpp
+++ b/firmware/controllers/map_averaging.cpp
@@ -227,7 +227,7 @@ static void mapAveragingCallback(trigger_event_e ckpEventType,
        measurementsPerRevolution = measurementsPerRevolutionCounter;
        measurementsPerRevolutionCounter = 0;
-       for (int i = 0; i < engineConfiguration->specs.cylindersCount; i++) {
+       for (int i = 0; i < 1; i++) {
                angle_t samplingStart = ENGINE(engineState.mapAveragingStart[i]);
                angle_t samplingDuration = ENGINE(engineState.mapAveragingDuration);
That (now I am not sure that such a change in the code is really necessary) connected with proper averaging start angle and duration angle gives a stable MAP reading form middle cylinder. Averaging 3 independent MAP sensors in my opinion will not increase the measurement range (currently 100-75 kPa) and the stability of readings.
Some info in subject of poor vacuum pressure in two-stroke engines and difficulties in tuning with MAP: http://www.msextra.com/forums/viewtopic.php?t=65104
This is a topic in which -- I must to admit -- I need to dig deeper. Even if I will use WO2 it will be used only for presetting/autotune, without any later operation in a closed loop (will be dismounted).
Posted: Wed Jan 24, 2018 2:12 am
it would be a tiny fix to put this into the official branch https://github.com/rusefi/rusefi/issues/549
Posted: Wed Jan 24, 2018 6:44 am
by sir
It would be very nice, but universal logic might be a little tricky. In the 4-stroke engine the intake stroke is once every two crankshaft rotations, and can be measured in angle after TDC. In a two-stroke engine, the 'intake stroke' occurs once per crankshaft rotation and can be measured in the angle that occurs before TDC of each clinder.
For my engine it is between 55 and 0 degrees before TDC of each cylidner -- this is angle window when piston uncover inlet port (during up movement) and mixture can be succed into crankcase. After my modification the MAP measurement only occurs for the first cylinder, so the measuring window must be in reference to the TDC of the first cylinder. For a 3 cylinder engine, each cylinder has a 120 degree shift in phase...
let's do some math:
- inlet opening start for 2nd cylinder: 55 deg BTDC + 120 deg = 65 deg ATDC of first cylinder
- inlet full open: 0deg BTDC + 120 deg = 120 deg ATDC of first cylinder
So in this case averaging should start at 65 deg ATDC of first cylinder and averaging window should be 55 deg (120-65) -- this are exactly settigns you can find in CurrentTune.msq which I attached a few posts above. In current shape of firmware there is no way to do it differently -- you can't specify averaging start window begining before TDC and can't to choose a specific cylinder.
MAP sampling start angle option set to 305 deg (-55+360 which is start opening window for the next engine rev) could be a workaround for first issue. I do not know if current firmware can handle it properly -- but TunerStudio certainly not (can't set this value above 90 deg, which is generally ok for 4-stroke engines).
Posted: Wed Jan 24, 2018 2:04 pm
Posted: Wed Jan 24, 2018 6:40 pm
by sir
Wow, that was quick! I just compiled fresh firmware and flashed testboard with it. It's working :) Checked in engine sniffer only, but it seems to work just as expected. For MAP on 1st cylinder I can set start angle at 305 deg or -55 deg, for 2nd at 65 deg and for 3rd at 185 deg. That's perfect! :)
