Jeep XJ 2500cc
Posted: Wed Oct 24, 2018 7:39 am
by matt
Hi all.
This is my friend Jeep Cherokee. Ecu got slightly burn at power supply circuit. I feel lazy to do repair on his ecu, so planning to make Rusefi running it. Something wrong with my phone, later I will upload actual picture.
Here is it look like:
- download (1).jpg (10.03 KiB) Viewed 11888 times
I see Rusefi decoder is for 6 cylinder, mine is 4 and probably it trigger is look like this:
- E_THEORY_html_1f9bb02a.jpg (17.25 KiB) Viewed 11888 times
Can you guys make this new type decoder?
thanks.
Matt.
Re: Jeep XJ 2500cc
Posted: Thu Oct 25, 2018 9:40 pm
Re: Jeep XJ 2500cc
Posted: Thu Oct 25, 2018 10:18 pm
I think it's ready? See
https://github.com/rusefi/rusefi/issues/615 for image, will update triggers list page later
Re: Jeep XJ 2500cc
Posted: Fri Oct 26, 2018 1:34 am
by matt
Many thanks!!!
I will update how it goes.
Re: Jeep XJ 2500cc
Posted: Thu Nov 08, 2018 3:06 am
by matt
Quite busy with life business, I hope I can start this Jeep by this weekend. I see trigger pic :-
Trigger offset is 484, so it is a rough number or solid?
Re: Jeep XJ 2500cc
Posted: Thu Nov 08, 2018 1:04 pm
TdcPosition is trigger oen business. You should use trigger offset zero.
Re: Jeep XJ 2500cc
Posted: Mon Nov 12, 2018 3:06 am
by matt
Consider my next project for BMW E30, what do you guys opinion about Aliexpress Max9926? Seller state it is original Maxim chip.
Re: Jeep XJ 2500cc
Posted: Sat Nov 17, 2018 8:18 pm
matt wrote: ↑Mon Nov 12, 2018 3:06 am
I am pretty sure these are fake or not exactly OEM quality, but could work good enough for our purposes
Re: Jeep XJ 2500cc
Posted: Thu May 02, 2019 3:22 am
by matt
Working on this car again, I see most of its wiring got slighly burn mark (wire insulation melting everywhere). Currently I change trigger to 16-1 running at cam speed. Do Rusefi support this?
Re: Jeep XJ 2500cc
Posted: Thu May 02, 2019 4:41 am
just skipped wheel 16-1 on cam? yes for sure
Re: Jeep XJ 2500cc
Posted: Thu May 02, 2019 6:14 am
by matt
Not much fund I got from this car owner. I do the trigger wheel which is very low cost. So this should work?
- IMG_20190428_204043[1].jpg (921.15 KiB) Viewed 11267 times
Re: Jeep XJ 2500cc
Posted: Thu May 02, 2019 9:16 am
Yes that should be able to be decoded.
Re: Jeep XJ 2500cc
Posted: Thu May 02, 2019 1:21 pm
I do not understand the picture above. Which part is the wheel? Where is the gap? Where is the sensor?
Re: Jeep XJ 2500cc
Posted: Fri May 03, 2019 12:36 am
by matt
russian wrote: ↑Thu May 02, 2019 1:21 pm
- IMG_20190503_073505[1].jpg (1014.5 KiB) Viewed 11240 times
Test with ms2= too much lost sync
Test with Speeduino= too much lost sync
Rusefi= Not yet, will do in next few day
