Page 6 of 6
Re: Nissan on Frankenso #47
Posted: Fri May 03, 2019 6:44 pm
by ZHoob2004
Take a look at your "Warmup fuel manual Multiplier" and "Intake air temperature fuel Multiplier" tables.
Currently, at 80c coolant and 34c air your base fuel is being multiplied by 1.06 and 1.9 respectively. This means your calculated base fuel pulse, the fuel you would use under ideal conditions, is being multiplied before your dead time is added to give your final pulse width.
0.635ms (base pulse) * 1.06 (80c warmup muliplier) * 1.9 (34c intake air temperature) + 0.85ms (dead time) = 2.12889ms
I estimated the IAT number from the graph, but I think I was pretty close. I'm not really sure why the tables are like that, if that was a default or an artifact of the recent change from percentages to multiplier values (I don't think the underlying values should have changed)
Posted: Fri May 03, 2019 7:03 pm
I would expect this to be pretty visible on the Formulas pane of rusEfi console?
Posted: Sun May 05, 2019 2:57 am
by filip5
Does anyone know how Rusefi handles sudden engine load increases such as AC engaged or turning the steering wheel during idle or in higher rpms?
Posted: Sun May 05, 2019 3:19 am
At the moment it does not respond to those directly.
Technically there is automation idle control which would compensate for load change.
Technically AC engagement should be considered as a reason to bump target idle RPM, but not implemented at the moment.
There is also acceleration enrichment see https://rusefi.com/wiki/index.php?title ... Enrichment
Posted: Sun May 05, 2019 8:16 am
Could FSIO increase IAC upon digital input? AKA known increased load could automatically increase air flow then the magic increases fuel.
Posted: Sun May 05, 2019 2:50 pm
You remember it right! FSIO formula #15 could be used to adjust target idle RPM
See https://github.com/rusefi/rusefi_docume ... rview/FSIO
Posted: Sat May 18, 2019 2:14 am
by filip5
I had hard time setting up the VE table properly so the engine could work on proper stoichiometric ratio with all temperature and variables changing.
To set this table right this is what I found out so I thought to share these finds.
1- Set the correct engine displacement volume in liters, mine is 1.86 Liters.
2- Set the correct injector dead time as per manufacturers specification, for my injector it is 0.85ms at 14 volts.
3- Set the correct injector flow in cm3/min. The correct value of the injection is not the manufacturers spec, but it is the spec divided by 0.8. My injector manufacturers spec is 440cm3/min but the actual injection as per test that I did was 545cm3/min, so one needs to divide the spec of the manufacturers injector by 0.8.
4- Set the IAt as per table in the picture attached varying as per intake air temperature.
5- Set the coolant temperature as per table in the picture but one can also leave these values at 100.
6- Set the VE values in table all at 100.
These values seem to work well.
Idling issues
Posted: Sun Jun 09, 2019 3:23 am
by filip5
I have Rusefi run on idle on separate Ve, advance ignition and Warmup Idle multiplier. I am doing this because the engine seem to start and run better on idle this way. I have the idle target set at 720 rpm and these 3 tables max rpm set at 725.
I have the normal Ve, ignition advance and the warmup table all start at 750 rpm. The thinking goes that as the rpm's increase Rusefi should take values from idle tables for all rpm's under 750 and then take the values from normal tables for values of over 750. This does not seem to happen. As rpm's increase above 750 , 1000 or more Rusefi still seem to take values from idle tables and not normal tables. The picture shows that ignition advance is stuck at 7.0 degrees for even higher rpm's that 750. 7.0 degrees is the max at idle table.
I can only get the normal tables to work if I set these values of Idle Ve, ignition and warmup to false.
The other issue is that the warmup idle multiplier table does not seem to work or at list not function during engine running. I also have a video which I can post if interested.
Can someone advise what should be done to get these items to work?
Attached are the pictures, the tune and the log files. Thank you
Posted: Sun Jun 09, 2019 4:02 am
by Abricos
for verification purposes ...
your temperature in the tuner studio and on dashboard is it same ? And on engine colant - air temperature is it same ?
Posted: Sun Jun 09, 2019 4:54 am
by filip5
Yes they are the same.
Re: Idling issues
Posted: Sun Jun 09, 2019 5:15 am
by andreika
RusEfi takes values from idle tables not because of the rpm but because of the TPS. That is, if the throttle is not pressed, then it's idle. Otherwise it's normal (working) mode. So if you want some different values for different RPMs on idle, it's ok, that's the idle table is for: the X axis is RPM, so you can set any values for any RPMs in those tables. But it will change to normal tables ONLY if the throttle is pressed. And this is good, trust me! ;)
Re: Idling issues
Posted: Sun Jun 09, 2019 5:24 am
Idle target is just what PID regulator is trying to get you. It's not a threshold for any logic. It's not "below 720 is idle, above is not idle".
It's more like "if throttle is not pushed and we run at 900, let's choke this engine - give it less air and try to get RPMs to 720"
Posted: Sun Jun 09, 2019 12:03 pm
by filip5
Okay thank you
What about idle warmup multiplier?
It does not seem to make any difference in fuel injection when adjusting it while the engine is running
Is this graph suppose to perform any function and adjust fuel injection as the engine gets hotter?
