Finelly I'm in process.
Yestarday I checked power suply for Discovery and VR- schematic.
All works well.
Next step ignition and injector drivers.
After that I'll try to run engine.
When all this will work I'll show you my schematic.
Test car Ford Fiesta XR 2i 1990
Re: Test car Ford Fiesta XR 2i 1990
Skype- max.mad486
So, after consultation with @ Russian I make some changes in Engine.h and compile RusEFI_Fiesta firmware.
Now ECU is clicking the injector when I move steel pen in front of a VR-sensor.
So now I'll work on ignition.
Skype- max.mad486
We demand updates
// spark 1 activated at the 1st tooth event while cranking & normal running
registerActuatorEvent(&config->ignitionEvents, 0, addOutputSignal(SPARKOUT_2_OUTPUT), 0);
// spark 2 activated at the 36th tooth event while cranking & normal running
registerActuatorEvent(&config->ignitionEvents, 0, addOutputSignal(SPARKOUT_2_OUTPUT), 360);
nothing weird in this code?
looks like a typo with SPARKOUT_2_OUTPUT
it does not matter - this code needs to be updated so that spark strategy is configurable via Tuner Studio
I was just wondering if that car actually ever started
speaking of spark strategy - could you please point me to where I can set up the dwell time? (you mentioned in some other thread that it's configurable?)
dwell time is now configurable via Tuner Studio.
As I've mentioned before, an overhaul of ignition configurability should be finished within a week, please hold on.
