[rusEfi] Mitsubishi 4G63 and 4G92 (#6)
Tambralinga
Re: Mitsubishi 4G63 and 4G92 (#6)
Post by Tambralinga »
Firmware have time out 1 minute?
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:What pin use for fan on Board Frankenso ?
You can assign fan to any pin of Frankenso or Frankenstein, you can customize this via TS.
Tambralinga wrote:Firmware have time out 1 minute?
No. I do not understand you here :(
Tambralinga
Ok, Problems with my cable.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
my frankenso
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:Image
Wow :)
I was suspecting something was going on :)
cool! two usb ports, embedded bluetooth! a set of microswitches, integrated power supply! what else?! sexy! what connecters are you using?
very nice very nice. Keep up the good work.
Also beware the DB connectors. Those were not designed for 1A of current flow, and is a common reason for problems on other system designs. I would suggest a better connector, or at least using the gold plated contacts for those connectors.
Tambralinga
puff wrote:cool! two usb ports, embedded bluetooth! a set of microswitches, integrated power supply! what else?! sexy! what connecters are you using?
DB9 : That for External LCD Display... any status.
DB27 : For external exhaust sensors.
:lol:
;-x
Skype : shiva-p
+66 8 5357 5159
Tambralinga
kb1gtt wrote:very nice very nice. Keep up the good work.
Thanks for your concern.
According to connector, I have nothing the right connector. Waiting for a new one should be strong connectors.
I have one question about Knock sensors.
I don't know in "Frankenso" can use or not. Because I have no experience in the Knock.
If you have any concern, please let me know.
Thanks.
Mr.X
:mrgreen:
Skype : shiva-p
+66 8 5357 5159
Tambralinga
my frankenso
Frankenso single board.
;-x
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:I have one question about Knock sensors.
The firmware for this is not ready yet, but it's pretty high on the priority list.
Tambralinga wrote:Frankenso single board.
This is pretty cool! Does it work? Did you run an engine with it?
Tambralinga wrote:I want to open solenoid at 5000-5500 RPM output signal GND to solenoid.
http://rusefi.com/wiki/index.php?title=Manual:Flexible_Logic
Tambralinga
Ok,Tomorrow I will test.
set_fsio 1 5500
set_fsio_pin 1 pd11
Use this command to open solenoid @ RPM 5500 or not
You have command for change fuel table 24x16 or 32x16 ?
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:set_fsio 1 5500
5500 what? this is not how this works - you need to specify that you are comparing 5500 and rpm
so, more like
set_fsio 1 "rpm 5500 >"
To get larger fuel maps you would need to re-compile the source code & adjust rusefi.ini
Tambralinga
set_fsio_pin 1 PE2
It does not work.
I want example for shift light open rpm 7000.
Skype : shiva-p
+66 8 5357 5159
Please update to latest version #5717
I have hard-coded something into your config, so you would need to reset configuration
set_engine_type 16
The hard-coded stuff is:
	setFsio(engineConfiguration, 0, GPIOD_11, "rpm 5500 >");
fsioinfo should show the state of. At low RPM, it shows
2014-12-07 10_35: EngineState: FSIO #1 [rpm 5500 >] at PD11@0Hz = 0.00000
2014-12-07 10_35: EngineState: user-defined #1 value=0.00000
At high RPM, it shows
2014-12-07 10_36: EngineState: FSIO #1 [rpm 5500 >] at PD11@0Hz = 1.00000
2014-12-07 10_36: EngineState: user-defined #1 value=1.00000
Tambralinga
new firmware set_engine_type 16 problems connecting to TS.
Connect no more than 1 minute disconnected.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
I want to change in the Y Axis maximum cranking coolang temp to more than 500.
I can not change my eclip have an error, you can change it.
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:I want to change in the Y Axis maximum cranking coolang temp to more than 500.
but why? 500 is already unrealistic.
Not sure which field exactly you are referring to, can you please share a screenshot?
Tambralinga
I want 700 maximum
Skype : shiva-p
+66 8 5357 5159
crankingFuelCoef = array, F32, 9504, [8], "%", 100, 0, 0.0, 700.0, 2; size 32
done
Tambralinga
Thanks, I'm going to test it.
Skype : shiva-p
+66 8 5357 5159
Tambralinga
firmware new version 26-01-58 have error led red show.
Skype : shiva-p
+66 8 5357 5159
Tambralinga wrote:firmware new version 26-01-58 have error led red show.
Anything on the LCD screen?
I think I have fixed it, please try latest firmware.
Tambralinga
my lcd damage Today I will test the new firmware .
Skype : shiva-p
+66 8 5357 5159
Tambralinga
russian wrote:I think I have fixed it, please try latest firmware.
not work for last firmware
Skype : shiva-p
+66 8 5357 5159
Can you reproduce this issue right from full chip erase & create a ticket?
https://sourceforge.net/p/rusefi/tickets/132/ is an example of a ticket with FULL & EXACT steps to reproduce. It also contains the exact version of the binaries where the problem is reproduceable.
Tambralinga
You have a command for a matching offset or silk create file ini ?
Skype : shiva-p
+66 8 5357 5159
Not sure what you mean here :( do not understand what is this question about
get_int command? set_int command?
