[Success Story] Ford Festiva / Protege / Miata motor (#3)
Re: Ford Festiva / Protege / Miata motor (#3)
Drew can you post on https://forum.chumpcar.com/index.php?/topic/9018-anyone-to-waste-time-on-diy-engine-control-unit/?
I posted over there, looks like there might be a few questions for you to answer....
Ford Festiva with Mazda Protege Block, Mazda Miata BP4W head and Protege intake w/mods, Ford Escort GT transmission ----- yup, it is a lemon!!! --- fun site https://mixdrinkenjoy.com
I was trying to run another ford festiva - called pride here -, ignition was good but unfortunately injection and all settings about injection were not !
I'd tied to increase/decrease injection flow, injection base time, and other, and nothing has changed.
- I just run TS on my laptop with new installation of Linux. and i copied TS from my working machine.-
So how i can check whats wrong ? i mean what exactly is wrong here .
I'd shared trigger signal with another ecu - original ecu of car - injectors were working.
Is time or something else wrong ?
Thanks.
Thanks.
Can you pull an injector and squirt in a container? Such that you verify your flow. Can you share crank signals with the oen ecu? Such that oem runs like 3 cyl while you tune only one cyl.
Need to migrate to fresh firmware maybe one day but right now attached is in the car.
this section was generated automatically by ConfigDefinition.jar based on rusefi_config.txt Sat Feb 02 20:30:30 EST 2019
- Festiva_in_the_car.zip
- (301.66 KiB) Downloaded 203 times
