Opel Corsa B, 1.8L
Opel Corsa B, 1.8L
hi guys , after a long wait finally I have the frankenso board in my hands and I started welding work.
-the board power supply work fine, tested.
-load the firmware successful in the smt32 board.
-the rusefi console connection work.
but i have many questions, whats it is the communication port for TS? i can use the smt32 microusb for this purpose? or only is possible by microusb TTL frankenso board?
i tried connection TS but an error message appears.
thanks, help me
thanks, help me
- IMG_7637.JPG (96.57 KiB) Viewed 11589 times
- IMG_7638.JPG (142.39 KiB) Viewed 11589 times
Re: Opel Corsa B, 1.8L
Cool
Soldering paste maybe? See http://rusefi.com/forum/viewtopic.php?f=4&t=425
Yes you can run TS via microUSB: you need to put a jumper on GND and PB1 pins & reboot stm32
See also http://rusefi.com/wiki/index.php?title=Manual:Software:TunerStudio_connectivity
See also http://rusefi.com/wiki/index.php?title=Manual:Software:User/en#Communication_mode
yes i use soldering paste, its the best method.
i'll try....
i'll try....
thanks russian TS work perfect!!!
Time for more pictures
One thing about the LED screens: they come from different suppliers and looks like they want different contrast resistor. One style needs 2K and another style needs 1.5K
Right now I've forgotten which one wants what value Looks at the traces and vias on the LCD pcb to see the difference.
- with_hidden_vias.jpg (84.68 KiB) Viewed 11545 times
- with_exposed_vias.jpg (80.39 KiB) Viewed 11545 times
hi, i try which 2k and 1k now.
- IMG_7695.JPG (130.04 KiB) Viewed 11539 times
Your settings looks right, great job putting everything together!
I believe I saw the same thing when my contrast resistor value was off. At some point I was actually considering asking Jared for a small tiny potentiometer instead of that resistor but I am not sure.
thanks! a small tiny potentiometer is a good idea , i try other resistor value
yeahhhhhh i put a 10k pot and works great...
Magic
Can you please take a good picture of the whole board so that we know where you are exactly? Once you are ready I guess next step would be decoding your trigger signal. See http://rusefi.com/wiki/index.php?title=Manual:Hardware_Trigger
Please note that I am currently changing a lot of stuff related to console and tuner studio under https://sourceforge.net/p/rusefi/tickets/157/ so connectivity could be a bit unstable for the next week.
hello guys ,step by step, the tach imput is ready now ... i tested on a jimstim to generate 60-2 signal. the next step should be to check the analog imput and ignition/injection output.
here a picture of my board:
- IMG_7706.JPG (811.95 KiB) Viewed 11533 times
http://rusefi.com/wiki/index.php?title=Manual:Hardware_Test_Mode could be helpful to test the board. I also like the LEDs on the outputs, they blink really sexy...
This is a bit scary to me - is that a piece with naked +12?
hi, this is 12volt source. i put in the fuse place for board test only
How is it going? Is there anything I can help you with?
Do you know your car trigger signal shape already? Is it 60-2 or something else?
hi ,thanks, yes its 60/2 vr , the board is ready to test in my car, all circuit are tested (ign, inj, sensors and tach in). I can wait to replace headcam gasket .Unfortunately broke last week. the next week will be ready to start..
