Coil and Injector driver IC
Post by 960 »
Hi!
I am looking for alternative drivers for injectors, coils, GP and ADC.
Do you have any suggestions for IC's that are good, and works with rusEFI?
What about something like this?
Infeneon TLE6220GPAUMA2
https://www.infineon.com/dgdl/Infineon-TLE8110ED-DS-v01_00-EN.pdf?fileId=5546d46261ff57770162008c5f7b2d59
Re: Coil and Injector driver IC
We have looked into these.
18 Channel Smart Lowside Switch TLE6244
https://rusefi.com/forum/viewtopic.php?f=4&t=577
Smart 16-Channel Low-Side Switch TLE6240
https://rusefi.com/forum/viewtopic.php?f=8&t=434
Higher voltage Common Rail MC33816
https://rusefi.com/forum/viewtopic.php?f=4&t=1337&p=29235
LowZ LM1949
https://rusefi.com/forum/viewtopic.php?f=4&t=431
Double channel high-side driver with analog current sense VND5E025AKTR
https://rusefi.com/forum/viewtopic.php?f=4&t=747&p=13402&hilit=vnd5e025aktr#p13402
Generally my concern about these specialty chips is the long the long term supply. The niche market tends to change and then chips like these become hard to obtain. As well these chips tend to have OEM performance. The injector drivers tend to have higher Rds characteristics which makes more heat and requires a larger heat sink. The more generic chips tend to have better characteristics.
960
Post by 960 »
Thanks!
Also, do you know any IC that are identical to this?
Jared forgot https://github.com/rusefi/rusefi/tree/master/hardware#user-content-modules about BTS21400 ignition coil IGBT driver
960
Post by 960 »
960 wrote:
Sun Dec 23, 2018 4:02 pm
And could this be used?
too many chiefs, not enough Indians :( This a relatively easy chip to learn KiCAD PCB design, would you be available to make a tiny prototype board for this chip?
960
Post by 960 »
russian wrote:
Sun Dec 23, 2018 7:19 pm
Yes, I can do that.
Bosch units use this one, which seems to have less amps.
http://www.bosch-semiconductors.com/media/automotive_systems_ics/pdf_1/ic_engine_management/bosch_ic_cy320.pdf
960
Post by 960 »
I finally found the right driver for the E-Throttle.
It is exactly the same as oem VAG, and a lot more.
Here it is:
https://no.mouser.com/ProductDetail/NXP-Freescale/MC33931VW?qs=sGAEpiMZZMvYc73DDAmzVgBNWijNCcrWnq%2f0bhIs9C8%3d
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
There is some talk about the MC33810 at the below thread.
https://rusefi.com/forum/viewtopic.php?f=4&t=576&p=15038&hilit=MC33810#p15038
Hmmm, I thought I had built a board for the MC33810 some years ago. I can't seem to find the KICAD files now. I think they went the way of bit rot.
Dron_Gus
Post by Dron_Gus »
kb1gtt wrote:
Mon Dec 24, 2018 10:00 am
I'm going to try this IC with my custom RufEFI fork for subaru EJ20... Someday...
EJ20 you say. As luck has it, I have one of those in the garage. It sits idle as it has massive electrical issues. The guy I bought it from really hacked the harness.
kb1gtt wrote:
Sun Dec 23, 2018 10:42 am
Figure 24 of TLE6240 datasheet is suggesting TLE8104E for 4 channels of injector control. TLE8104E is cheap and available :)
960 wrote:
Sun Dec 23, 2018 11:16 pm
Here it is:
The ST L9960 is also a pretty good option, and has a package for dual drivers. Has SPI fault detection, fully protected, etc.
Re: the actual question, I’m a fan of one-chip-per channel. The area penalty isn’t too significant, and with a sensible package like d2pak, the exact part might not always be available, but SOME equivalent protected low side switch will always exist.
