I was putting it back into the car with the frankenso board bolted onto its PLASTIC base and somehow I must have touched the ratchet to something under the dash that is live even when the car is off. flash of sparks and now the discovery seems to be dead.
What I don't get is the Frankenso and Discovery are completely insulated from the mounting bolt, (the bolt is on the dash structure so is an earth point and I have no idea what was live, nothing should have been where I was working), the case is deliberately isolating the actual board from the dash structure so I don't quite understand how earthing out something via a bolt through a plastic tray has killed the discovery board but it appears to have happened.
The ST link side of the board will connect to the PC just fine but the Micro USB side no longer connects. The firmware is clearly not running anymore as the coloured lights between the the 2 sticks on the board are not lit and jumping the stimulator pins achieve nothing.
Worse than that if plugged into the frankenso board it lights the 5v power supply light, the crank signal light (didn't before) and one of the injector driver lights....
Am I correct in thinking that when I plug the micro USB into the PC I should get a com port appear? Cause I'm not getting one of those.
Any suggestions on debugging the Discovery boards to confirm the death?
Have a giant Norwegian blue... I can assure you its fine....
