analog inputs: op-amp + divider - Russian - now MCP6004
Re: analog inputs: op-amp + divider - Russian - now MCP6004
New much tighter version available at https://github.com/rusefi/hw_modular/tree/master/Analog_Input_Module
Just ordered the first batch.
960
Post by 960 »
Please note all diodes needs to be soldered different. I used the frankeso symbol that has wrong pinout :-(
960
Post by 960 »
I am updating the module with the right symbols now.
This is just another example of what issues the hated rusefi lib does.
I even used a micro usb symbol with d+ and d- switched.
It's at the uart on the boards you got from me.
It took me a long time to figure out..
So please follow my advice to make steps to get rid of it, instead of letting it grow.
For this, you need to put the diodes upside down, and turned
Ahmad
Post by Ahmad »
I found L9966 for analog inputs of my custom ECU.
But I cant find any datasheet!
