Looking for a bit of advice setting up the cam and crank triggers. The engine has three teeth on the crankshaft, each one representing 120° of engine rotation. There are equally spaced teeth and windows with a hall type sensor. There is also a single tooth camshaft sensor that represents 180° on, 180° off of camshaft rotation. Basically it shows on for one engine rotation and off for the second.
Both sensor signals are fed to the OEM computer has a square wave, not sure if it is open drain or voltage source.
Is there an existing configuration in the firmware? If so, which one do I use?
Trigger wheel setup
SHOf429
Trigger wheel setup
Josh
94 Ford Taurus SHO
Frankenso in progress
94 Ford Taurus SHO
Re: Trigger wheel setup
You would need to click a few menus to describe that configuration. See two images at https://github.com/rusefi/rusefi_documentation/issues/59 which I believe accomplish what you are looking for.
