Wifi Wireless connection
- Github Username: jiafu400
After several days of testing wifi, it is now possible to connect vehicles remotely
- HD`_DBP%XF6GJG7A)INI8[3.png (310.54 KiB) Viewed 5973 times
- IMG_1546.JPG (2.93 MiB) Viewed 5973 times
- IMG_1545.JPG (3.15 MiB) Viewed 5973 times
Re: Wifi Wireless connection
Please provide more details!
I see probably first known to be USB-C board What wifi module did you use?
Also very interesting board. I see no TLE.
We absolutely need more info!
The board is designed for compatible use with Rusefi and Speeduino, which firmware can be used. The above picture is inserted into USB cable for power test. The wifi module is made in China, which can realize TCP/IP LAN and remote IP connection
https://detail.tmall.com/item.htm?id=570631484081&spm=a1z09.2.0.0.4a9f2e8dKAj2GB&_u=i1s76pamd43c use without having to write any code, set up the communication baud rate, The video cannot be uploaded here. The following picture is the communication baud rate screenshot and the communication picture of PC side
- (WX[X95LB$[$(S2~]G{H@%4.png (56.35 KiB) Viewed 5919 times
- B67RXKNARG5N(08NNIBJU41.png (162.12 KiB) Viewed 5919 times
- IMG_1547.JPG (3.5 MiB) Viewed 5919 times
- IMG_1548.JPG (1.82 MiB) Viewed 5919 times
- IMG_1549.JPG (3.29 MiB) Viewed 5919 times
This board is a private project or you will make it open source?
(The MRE board )
(The MRE board )
- Github Username: Loft-xiaolen
Although I understand you both speak the same language, please make sure the public forum side facing part is in English. In private, feel free to do whatever you like. Thank you.1065598263 wrote: ↑Sat Jul 30, 2022 8:15 pm大哥可以加微信交流吗?
https://rusefi.com/forum/viewtopic.php?f=2&t=2388&p=45967#p45967
这是我的帖子,我有太多东西需要请教了。
"Dave B. 5:03 PM
OK, OK, sorry, I'm so excited.nmstec wrote: ↑Sun Jul 31, 2022 1:40 amAlthough I understand you both speak the same language, please make sure the public forum side facing part is in English. In private, feel free to do whatever you like. Thank you.1065598263 wrote: ↑Sat Jul 30, 2022 8:15 pm大哥可以加微信交流吗?
这是我的帖子,我有太多东西需要请教了。
