MRE addon Board - Wideband controller + SD Card slot + EGT Chip
JRD McLAREN
Re: MRE addon Board - Wideband controller + SD Card slot + EGT Chip
Post by JRD McLAREN »
I have some addon boards for sale ... :arrow:
JRD McLAREN
..working on a new version of this board....
JRD McLAREN
...the world's first dualcore MRE in ALU case... :mrgreen:
JRD McLAREN
PCB ver. 2.5 in real life ..
It is still the same mck1117's WBO2 controller, but it has prepared OPAmps (U7) for analog output
(some testing and coding are needed)
....and it can be fitted into the ALU case without any modification ...
JRD McLAREN
..10 boards assembled ...
JRD McLAREN
my "dirty" github repository.. for firmware
It contains build directory for f0_addon board.
Last HW have footprints for OP amp.
It can be used as AUX outputs.
Now I need help with code, to see any "usable" output on AUX pins.
https://github.com/JRDMcLAREN/wideband-2311-f0_addon
