Fix for UAEFI sometimes not starting without USB connecteed
gurov
Github Username: ggurov
Slack: ggurov
Post by gurov »
from discussion on discord:
5vp does not light up with just 12v below a certain battery voltage, causing a no-start condition
this was traced down to a severe enough drop at the main 5v regulator that would cause the main MCU to power down, aborting enabling 5vp, entering a loop.
fix is rather crude, but it's to force 5vp to initialize forcefully, MCU or not.
10k resistor between pin 7 and 5v rail, like in the picture.
Re: Fix for UAEFI sometimes not starting without USB connecteed
gurov wrote:
Thu Apr 11, 2024 10:30 pm
We still do not know real root cause right?
Similar looking boards one would work another would not, right? https://github.com/rusefi/uaefi/issues/59
gurov
Slack: ggurov
Post by gurov »
correct, still don't know the actual root cause, just breadcrumbs of symptoms with comparison to good board
