EFI hand tools
EFI hand tools
Stihl has EFI chain saw and concrete saw.
Re: EFI hand tools
Is that a 35ohm injector with peak&hold at 50volts?!
unfortunately my source of part photos is eBay "STIHL MS 500i MS500i Fuel Injector "
Re: EFI hand tools
Interesting, some are clean some are dirty.
Re: EFI hand tools
Position sensor seems to have blue plug (see first post for eBay photo) with three wires, one position unused.
Fun fact - unused position is what I believe is ground. So, ground pin is not used by position sensor - neither of the three used wires are buzzing to "power" ground.
Voltages are measured against that unused ground pin.
First scope is against that unused power ground
Two other scopes are using are with alligator clip on one of the three wires more or less randomly. All data captured while saw is running.
