[help needed] Create a board without github
Jadam1
Post by Jadam1 »
Hi,
I design own board based on "uefi c" boards. Next i would like to add to my board a WBO and MAP sensor but do not know how do this - I don't know which scripts use. Can I do this without merge by github?
I will be very happy for our advices.
Best regards.
Jadam1
Post by Jadam1 »
Hi,
Best regards.
Jadam1
kicad-cli command not found
Post by Jadam1 »
Hi,
I would like to create an own ECU-board.
I follow the instructions from this URL:
https://github.com/andreika-git/hellen-one/tree/master?tab=readme-ov-file
But in step 5 I try to run export.sh on my PC - I don't use github merge.
When I run export.sh i get this command:
bash: kicad-cli: command not found
Can somebody help me?
Best regards.
Re: Create a board without github
Sounds like github is actions is your best option, what prevents you from using it?
Jadam1
Post by Jadam1 »
I have thought that I can doing it on my PC because I never use github.
But if you say that using github is best action so i have to sign up in github and trying it.
Do you have more detailed instructions https://github.com/andreika-git/hellen-one/tree/master?tab=readme-ov-file step 5?
Thank you for your reply.
Best regards.
