Digital Dash Project based on STM32 MCU and TOUCHGFX
Omen234
Github Username: romioRN
Re: Digital Dash Project based on STM32 MCU and TOUCHGFX
Post by Omen234 »
Omen234
Post by Omen234 »
here is the link to the repository
https://github.com/romioRN/Dash_st800
Omen234
Post by Omen234 »
I see a starting rope, does it start from the rope?
mi-hol
Github Username: mi-hol
Post by mi-hol »
Omen234 wrote:
Thu Nov 07, 2024 9:35 pm
the link gives a 404 not found error. Is it a public repository?
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
Omen234
Post by Omen234 »
Try again
mi-hol
Post by mi-hol »
Thanks, works now
Best Regards
Michael
Omen234
Post by Omen234 »
added an eprom and returned an ESP32
Omen234
Post by Omen234 »
Omen234
Post by Omen234 »
добавил репозиторий с кодом
https://github.com/romioRN/Dash6.8_firmware
Omen234
Post by Omen234 »
Omen234
Post by Omen234 »
we made an ESP32 server with a test engine monitoring page
Omen234
Post by Omen234 »
updated the case again
Omen234
Post by Omen234 »
Omen234
Post by Omen234 »
itsrealfast
Post by itsrealfast »
Hi,
I downloaded the github files but I dont see the latest version with ESP32. Is it possible if you can upload it? Do you have the updated firmware?
I am planning ordering pcb and components. The goal would be to adapt it on my Yamaha jetski
Please let me know
Thanks
Omen234
Post by Omen234 »
I'll update the repository later. I'm adding the USART exchange protocol. Hopefully it won't take too long. I plan to do it in a week and then how will it turn out
Omen234
Post by Omen234 »
Enigma2023
Post by Enigma2023 »
There is still an issue with ~$рама платы L.SLDPRT not working in solid works nor fusion 360. Can you provide updated file?
bgd_c66
Post by bgd_c66 »
Omen234 wrote:
Thu Nov 07, 2024 9:06 pm
Hello,
Found this forum while searching for a digital dash for my nissan patrol, which has analog gauges, and immediately thought that it's what i need .
I can gather the analog signals and send them through CAN bus to this dashboard.
From your perspective ,i can build the hardware, is the software difficult to understand for a beginner ?
Is my idea ,of converting the analog data to can, even going to work with this digital dash??
Omen234
Post by Omen234 »
Enigma2023 wrote:
Wed May 28, 2025 5:55 pm
https://github.com/romioRN/Dash_6.8-hardware/blob/main/3d%20model/silicone%20casting/рама%20платы%20L.STEP
added the STEP files. If you want to open it in SolidWorks, you need a version not lower than 2024 SP5.0
Omen234
Post by Omen234 »
Omen234 wrote:
Thu May 22, 2025 6:55 am
updated the firmware and the board
updated the board firmware and 3D models
Omen234
Post by Omen234 »
bgd_c66 wrote:
Sun Jun 15, 2025 11:11 am
Hello,
I think you should be able to do it because I'm a beginner too. the code is not very complicated yet and seems to be more or less understandable . CAN reception without any problems
Enigma2023
Omen234 wrote:
Mon Jun 23, 2025 9:05 pm
Thank you. I was able to use this version in Fusion 360.
bgd_c66
Post by bgd_c66 »
could you share the firmware for the first pcb?
the black one without wifi and buttons
Omen234
Post by Omen234 »
The firmware from this repository is suitable for all black boards.
Omen234
Post by Omen234 »
Omen234
Post by Omen234 »
Serious errors were found in the schematic diagram. I will post the corrected board later
Omen234
Post by Omen234 »
Omen234
Post by Omen234 »
I corrected the schematic and the PCBs for both versions. Now everything starts up and works well.
https://github.com/romioRN/Dash6.8-hardware
