[info] Proteus - Waterproof, High-feature ECU!
JRD McLAREN
Re: Proteus - Waterproof, High-feature ECU!
Post by JRD McLAREN »
as you say .. You have two identical setups ...
but two different fuel pumps ...
one is wrong, maybe ...
poor condition, different type of DC motor ...
(no caps and/or inductor inside, etc)
..and VNLD5090 can't handle this situation ...
try to use different type of load (bulb .?? ) on this output ..
Atlantis2013
Post by Atlantis2013 »
Hi everyone
BTS4175SGA isn't available .
Can use BSP762TXUMA1 for remplacement ?
Thx
Atlantis2013 wrote:
Fri Dec 01, 2023 3:00 pm
https://rusefi.com/forum/search.php?keywords=BSP762
Bruno Ferreira
Github Username: ECU-tech
Post by Bruno Ferreira »
The Proteus v0.7
See pic1,pic2,pic3 and pic4,there are thin traces like pointed on the every copper layer and they do not connect the pads around them,so the thin trace will be cut after production.
And the width of them are less than 0.15mm,which are too small to make.
If this is correct, I suggest updating these points.
I don't see this issue either in KiCad or in the official gerber output files.
Bruno Ferreira
It's just a production defect. When printing layers, the machine only prints with quality from 0.15
I changed them all to 0.5588
Perfect Gnd contact and no hot spots
pc1010
Github Username: pchmura4
Post by pc1010 »
Hi!
Did anyone manage to make EGT work on Proteus board using the AUX SPI connector?
It looks to be laid out on SPI5 port
At the moment rusEFI focuses on spi1 to 3 with one random spot mentioning spi4. Do not see any spi5 code anywhere.
custom spi_device_e 1 bits, U08, @OFFSET@, [0:2], "Off", "SPI1", "SPI2", "SPI3", "SPI4"
kneelo
Post by kneelo »
Got a question for the smart people...
Why are lowside outputs 13,14,15 & 16 the only ones with flyback diodes build in?
Im having some issues getting my VVT solenoids working at high PWM frequencies and I think it might need a flyback diode to fix the issue (well thats what im going to try next anyway). Looking at the schematic 4 outputs already have them! Just wondering why only 4 and not all of them?
kneelo wrote:
Sun Aug 11, 2024 12:08 pm
Because back-feeding with relays and not desired with injectors.
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Fly back diode will slow down injector closing. That may be an issue. So this diodes are not installed on injector channels.
paleppp on discord has the craziest Proteus enclosure
cast polyurethane option - not mine
mk e
Post by mk e »
I'll start with an apology if I missed it, but what is the current limit on the h-bridge?
I have a 2.1ohm actuator so it pulls an honest 7A which is why I ask.
TLE9201 is a 6A H-Bridge
mk e
Post by mk e »
Sun Nov 10, 2024 5:12 am
Any chance 2 channels can be bridged?
Do you mean can we parallel 2 h-bridge chips to drive more amps in a single TB? When you say bridge an h-bridge what are you looking for?
See notes about parallel topology below.
https://electronics.stackexchange.com/questions/515041/can-we-or-should-we-parallel-h-bridge-module-for-increse-current#515046
mk e
Post by mk e »
kb1gtt wrote:
Sun Nov 10, 2024 11:42 am
Yes, parallel H-bridges to a single TB. 10 years ago? when I was last ECU shopping the motec spec sheet listed 5A h-bridges with a note that 2 may be be bridged for 10A output, today they are listed at 9A high/12A low and no mention of bridging, but kind of not needed with the new specs. My current ECU on the other hand uses a 2 channel 5A chip with all the PWM logic built in and no way to sync the outputs so I had to run a larger external h-bridge. The TLE9201 chip appears the track a PWM from an external source, so I'm guessing supplying matching inputs to 2 chips will yield matching outputs and the theoretical ability to run them in parallel?
Tunerstudio does allow me to select throttle 1 on 2 channels....no idea if the software in the ECU would do it though.
If not, I'll need to find an external solution that works with the available outputs to make it viable. This is kind of a me problem, but it is an off the shelf BMW throttle actuator so not a problem I invented.
I think from a hardware standpoint they can technically be parallel-ed but I'm not sure if they would double the drive capability. If one bridge has less ohm that will be favored and will reach capacity quicker. I think the technical hurdle is software. It's possible that out of shit luck it might work as is. However I don't think the syncing with the intent of parallel operation was a planned feature.
Knowing you, I should encourage you to pick up a handful of beach sand squeeze it with a hefty grunt and make a chip which can handle more amps.
More practical solution, can you find a chip which can handle the amps you want? I know h-bridge with more amps is possible. It might have to be something with external MOSFETs. It shouldn't be to hard to spin a variant with more amps per channel.
mk e
Post by mk e »
kb1gtt wrote:
Sun Nov 10, 2024 3:42 pm
I think from a hardware standpoint they can technically be parallel-ed but I'm not sure if they would double the drive capability. ....It shouldn't be to hard to spin a variant with more amps per channel.
I don't need double, I need 16.667% :) Circuits and software are not my thing, all I know how to do is look at specs and buy them and this spec is a conflict. If the consensus is it's a terrible idea to run them parallel I'm certain an external device can read and duplicate the output with the amps I need, just an extra bit to think about and find a home for. As I said I'm already running a h-bridge external from my ECU but was hoping to do something cleaner.
R129SlSexy
Post by R129SlSexy »
Hello to the smart people of rusefi. I Would like some help. Can anybody help me thru the process of ordering the proteus thru jlcpcb? Ive been trying with just the latest files on 0.7 but ive been getting errors like (The below parts won't be assembled due to data missing.
R1207,R1219,U502,U501,U402,U401,U302,R1220,R1212,REF**,U11,U10,U301,U202,U201,U1004,U1005,U1203,U1204 designators don't exist in the BOM file.) and some parts are out of stock etc. Any help is appreciated!
DrahtFahrzeugHammer
Github Username: DrahtFahrzeugHammer
Post by DrahtFahrzeugHammer »
R129SlSexy wrote:
Sun Sep 21, 2025 7:59 pm
Hi there! Where are you located? If you are in europe i still have 3 spare Proteus boards including connectors and pins. If you really want to spend 1000 bucks or more on 5 boards including connectors i can help you with that too. Would be easier to discuss that on discord though
R129SlSexy
OK if you want add me on discord. r129sg
