Alternator field control circuit
Re: Alternator field control circuit
It just works :)
gptech2444
Post by gptech2444 »
russian wrote:
Wed Apr 11, 2018 12:05 am
It just works :)
Ok, but where and how do I get hold of this circuit? And where is it documented to set it up?
edit
I've ordered the IC from Mouser, was $4.73aud
gptech2444
Is it as simple as this? Where do you place the diode for flyback?
Is not miata alternator controlled by just logic level pwm signal? I believe my 2001 miata controls the alternator with only frankenso as is.
On dodge neon yes we used that large mosfet with the small addon board. I need to document better when i get home on Saturday
gptech2444
russian wrote:
Wed Apr 11, 2018 11:34 am
Yes, you are correct, I thought we still needed some external chip before the alternator.
https://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_1999
