MX7-C-35PL-C11 35 pin connector
Posted: Tue Nov 22, 2016 3:32 pm
by russian
Re: MX7-C-35PL-C11 35 pin connector
Posted: Fri Nov 25, 2016 3:08 pm
by russian
Board ordered as 2oz (takes more time)
Seems like Oshpart has improved their processing software to merge two drill files - previously they were only using one file and it did not go well for us.
Posted: Mon Dec 26, 2016 3:32 pm
by russian
board looks good
Posted: Mon Dec 26, 2016 6:47 pm
That's good news. Looks good.
Posted: Thu Mar 30, 2017 9:07 pm
by russian
Finally getting back to making the harness but this board has the same silkscreen offset issue as
http://rusefi.com/forum/viewtopic.php?f=4&t=687
While we are on that can we also make traces wider as well? Could be same issue with copper rings too large.
Posted: Thu Mar 30, 2017 10:09 pm
Which revision is your board marked? We have a couple out there now are we sure you have the correct revision? Just trying to make sure we are all on the same page, as I don't have eyes on it.
Posted: Thu Mar 30, 2017 10:11 pm
by russian
That's a young board, only 0.1 was ever ordered - that's the revision i have.
Posted: Fri Mar 31, 2017 12:40 am
Oh, that's a different board. I changed the mask to 0.003, and fattened up the traces where I could. Draft committed.
Posted: Fri Mar 31, 2017 12:46 am
by russian
I need your gerbers and your suby (once I get I larger garage)
Posted: Fri Mar 31, 2017 9:14 am
Gerbers generated and committed.
Posted: Fri Mar 31, 2017 3:03 pm
by russian
kb1gtt wrote:Gerbers generated and committed.
I know what i have forgotten to ask for
Can you please add pinout silkcreen on the back side as well? That's only needed for wiring half of the connector - the connector pads are covered by plastic.
Posted: Sat Apr 01, 2017 1:37 pm
Silk screen added, and re-committed.
Posted: Sun Apr 02, 2017 2:57 am
by russian
kb1gtt wrote:Silk screen added, and re-committed.
Thank you! Just ordered new boards.
