BTM112 Bluetooth
nighthunter
BTM112 Bluetooth
Post by nighthunter »
Hi.
Today i populated my board with a BTM-112 bluetooth. It works, but every time, when i Burn settings (close every dialog). It gives me timeout and i must reconnect. It seems that the settings are stored, but it is really painfull everytime i edit tables to reconnect. USB works OK. Is there a way to tweak this problem?
Re: BTM112 Bluetooth
Somewhat relevant to https://github.com/rusefi/rusefi/issues/336 which is currently the most annoying defect, but maybe not.
in rusefi.ini file a few parameters could be tweaked:
pageActivationDelay
interWriteDelay
blockReadTimeout
Can you try different settings?
I'd say the first thing to do is to fix https://github.com/rusefi/rusefi/issues/336 via microUSB. In orde to fix that via micro USB first step is actually be able to reproduce it with 100% reliability, because the problem seems to be coming and going.
Can you help by finding exact steps to reproduce the microUSB page 0 burn problem?
nighthunter
Via the USB i have no problem with Burn Page 0 Failed. I had this problem sometimes on the original discovery board. In my PCB design i doubled all the blocking caps around the MCU and now i havent had this problem. So i would guess if it is not a power/transient problem? Next days i test tweaking the timeouts in TS.
