Re: Common Rail MC33816/PT2001 dev board - 4 injectors GDI
Posted: Mon Jun 20, 2022 12:11 am
Chris says that Design Simulator Environment for PT2001 PSC - Standard
ASA-PT2001-STD
is the smart way to develop for this chip
Posted: Sat Jun 25, 2022 3:42 am
In 2018 I've made a hole in TPIC
Nick made a hole in TLE8888 last year?
Chris follows this fine tradition with NXP
Posted: Sat Jun 25, 2022 6:09 pm
by Abricos
Yes first MRE
Still work correct no problem same tle 8888
Posted: Mon Aug 15, 2022 6:07 pm
Rev C is one JLC fabrication defect I cannot sale those. Trying to get a refund via "Quality Complaint", hopefully I would not have to go credit card charge back route. https://github.com/rusefi/rusefi-hardware/issues/143
Intention was for the boards to operate as 4 injectors + 1 pump from factory, and to fit into the stamped case.
Boards now fit in the stamped case!
I do not see signs of pump control.
On bench I have firmware with default settings, power/GND and GDI injector hooked to simulate pump. When I ground control wire pin 41 "IN_PUMP" nothing happens
When I hook same injector as injector 1 and ground control wire pin 44 "injector 1" I have injector clicking as expected.
I am able to reproduce with both rev A and rev D on the bench. GDI4 fails to initialize the chip as long as I have three injectors just connected to the board - one acting as fake HPFP and two others have to be on different banks.
Posted: Mon Jul 10, 2023 4:19 pm
With a few issues fixed it looks perfect
Posted: Fri Aug 18, 2023 4:34 am
on a bench during heavy duty cycle clocking boosted voltage falls down the cliff around 5300 RPM
