Main Board PROG USB connector
Post by stefanst »
My brain seems to be on vacation. We have a "PROG" USB connector on the main board. I'm pretty sure I used it on my previous rusefi. However, I can't seem to make it work on the latest one (Board #82). Is there a jumper to enable it that I forgot about?
BTW: Building this one for a '91 Miata with VVT engine swap. Just like the humpback.
Re: Main Board PROG USB connector
I believe it is best to flash firmware via top green board connector and change settings via bottom green board micro usb connector.
Usb port is smarter thus more reliable than red board ttl prog port.
Post by stefanst »
There's my problem then. I was trying to conenct to Tunerstudio via the "PROG" port on the mainboard. That's not going to happen, is it?
So TS is still either the Micro-USB, or Uart to PC10 and PC11 or whatever that was- correct?
Prog is for native stm32 on frankenso only is not it?
Post by stefanst »
Correct. Hence my brain-fart problem.
