[info] TLE7209 or MC33186 H-Bridge Breakout
russian
Soldering skill: yes
Coding skill?: yes
Post by russian » Sat Mar 09, 2019 9:39 pm
We need some H-Bridge so why not TLE7209 or MC33186, these seem to be compatible enough and some older versions available from China?
TLE7209-3R has recently replaced TLE7209-2R seems to be pin compatible.
See https://github.com/rusefi/hw_modular/tr ... e_Breakout
iBom https://rusefi.com/docs/ibom/TLE7209_Module_latest.html
Coding skill?: yes
Re: TLE7209 or MC33186 H-Bridge Breakout
Post by mck1117 » Mon Mar 11, 2019 5:25 am
Why would we ever use an NRND part when there are better parts available for less money that are still active? Seems pretty foolish to pick a random part without any research, especially one that’s NRND.
For example the ST L9960 is designed for ETB applications, automotive rated, fully protected, adjustable over current protection, SPI fault detection, etc. Oh, and they’re <$5 in single quantities. And there’s also a variant that’s two chips in the same package to save space if you need to drive two motors.
russian
Coding skill?: yes
Post by russian » Mon Mar 11, 2019 5:44 am
Top message corrected - there is a TLE7209-3R not NRND recent revision.
russian
Coding skill?: yes
Post by russian » Mon Mar 11, 2019 5:46 am
PS: I am always open to any other suggestions. As someone begging for any help, KiCad help included, I would love to have any other H-Brigde breakout board, ideally with a two-row side connector.
960
Coding skill?: yes
Post by 960 » Mon Mar 11, 2019 7:44 pm
I dont think that TLE7209 is picked random without any research.
That's actually the driver found in each and every Bosch-ECU for almost 20 years now.
Coding skill?: yes
Post by mck1117 » Wed Mar 13, 2019 12:59 am
Ah okay. The OP made it sound like it was already decided, and provided no context or reasoning :)
The Infineon and ST parts look quite similar functionality-wise, but the Infineon is kinda hard to source. I'm not a fan of sketchy ebay parts. The older 7209-2 is available from normal places, but it's NRND. The new -3 isn't in stock anywhere (yet?).
The interface on the L9960 and TLE looks similar enough that they may be compatible (save for SPI commands and stuff), so I tacked a few L9960 on an order I was already placing.
@russian : what kind of connector is useful on the edge of the board for you?
russian
Coding skill?: yes
Post by russian » Wed Mar 13, 2019 2:00 am
For this to be used on the blue nucleo wing it would be great to follow the viewtopic.php?f=4&t=450&p=32039#p32039 and viewtopic.php?f=4&t=1471#p31990 using viewtopic.php?f=4&t=1473#p32038 header
960
Coding skill?: yes
Post by 960 » Wed Mar 13, 2019 11:08 am
The7209-2R are still in stock at both Mouser and Infineon.
The 7209-3R looks to be just a new revision, and it might be they want to sell out the 2R before releasing.
NXP also have newer versions than the 33186 that are identical.
These seems to have become the "standard".
So by using them, we are sure they works perfect with all E-throttles made the last 15-20 years.
(Standalone ECU's like LINK and MaxxECU use it as well)
russian
Coding skill?: yes
Post by russian » Sun Apr 28, 2019 10:58 pm
Just ordered first batch at jlcpcb
russian
Coding skill?: yes
Post by russian » Sat May 25, 2019 11:10 am
